Question about NEC Televison & Video
Model ndrv-61 nec dvd recorder. having problems playing dvd's wev'e played previously comes up as disc unrecognised. We have reset to factory settings nothing has helped.
  • 3 Answers
I have had similar problems and now I produce all new DVD's in DVD-R format and they are recognised. Any DVD+R will continue to deliver the same "unrecognised" disc error.
Posted on May 01, 2009
Cannot play this disc
As long as you are sure about using DVD-R which is the most common then i can only assume it did not finalize the disc.
Sep 02, 2014 | Televison & Video
NEC DVD Recorder/Video Cassette Recorder Model NDRV-60 will not work.
You have done and just about checked everything you can. You might want to check out the power supply components for bad swollen, leaky caps that may be affecting voltage levels and the operation of various boards on unit. Otherwise you might just have to get one on the cheap via ebay, garage sales, etc. Hate getting rid of stuff that is almost in mint condition but is not working - I'm running outta room!
Aug 25, 2017 | NEC Televison & Video
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
Dvd player will not play new discs, comes up as "unrecognisable"
this is bult in to stop piracy buy a cheap dvd that plays all regions ,b you be able to watch even the they sometimes struggle with copies
Aug 29, 2009 | LG LH-RH360SE Theater System
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
LG RH278 HDD/DVD Recorder
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
Feb 03, 2009 | LG DR787T DVD Recorder
DVD player won't regonise the burn't disc?
This model will only play the prerecorded dvds....your other one I bet is not the same model number!
hope this helps
Dec 11, 2008 | Televison & Video
Not reading pre-recorded dvd's and ocassionally not re-wrtten dvds
Over recent months my recorder has stopped reading pre-recorded disc's and more requently re-writer disc's. I had thought that the region had some how been altered, but not too sure now. Is there a way of checking? Or is there a problem with the laser block. I have stripped the machine down and thoroughly cleaned (but no dust found) and no loose parts. I have reset to manufacture default but this hasn't helped.
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK 1 Other User Has The Same Problem Comment by Guest, posted on Dec 19, 2007 DVDR70-051 recorder functions generally becoming more and more erratic. DVD-RW discs I have recorded sometimes say 'disc error' sometimes 'no disc' sometimes start ok but cycles round and round for 5 - 10 mins before stopping, sometimes goes straight into play at last position, won't stop back in menu just goes straight to stndby. Factory reset dosn't help. Wont play pre-recorded discs without going into menu and messing around. It seems to damage or not record RW discs properly a lot of the time. Not even sure if it's resetting to factory settings properly.
Oct 28, 2007 | Philips DVDR70 DVD Recorder
Cyberhome dvr1600 problems
Try cleannng machine with dvd cleanner if u have staples surplus near u it only costs 10 can cn twice thiswoked for me had a same promblem.
Aug 10, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
100 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
