Question about Palm Tungsten T5 Handheld
Interrupted update - jammed
My Palm T5 is not working. [It is also out of warranty]. I performed the original 1.05 flash BIOS upgrade as recommended by PalmOne - successfully. I attempted a second upgrade to v1.1 [recommended by PalmOne also]. Because I was using a laptop instead of a desktop the laptop battery went flat. [I had just bought it 2nd hand and the battery wouldn't hold its charge - but I didn't know this at the time] The outcome for the Palm T5 was an interrupted update. Now the screen stays on till the T5 battery runs flat. Also the T5 screen stays on for ever if you plug it into the mains adapter. [unless you do a reset - after which it comes back on immediately afterward] The screen that stays on has a grey background with a rectangular panel saying "PalmOne" in orange and brown letters. After a hard reset there should be a progress bar finishing in a round grey "Palm" logo on grey background with a question "erase all data?" After confirming the erase by pressing the up navigator button - the screen should blank out and do a 10 minute zero out reset. [It does this 10 minute reset OK but without the round grey logo and the progress bar and without the erase all question] All the resets apparently work OK - ie soft - hard - zeroed out reset. The buttons all work so far as I can tell. Since the screen manages the control buttons does resets and writes "PalmOne" the processor is functioning OK. Hotsynch is the major problem. It appears impossible to initiate a hotsynch by any commonly used means eg cradle - cable - buttons etc. Without hotsynch I cannot reflash the T5. I tried running the T5 battery right down over 4 months in case it was retaining bad info in RAM - this didn't help. It would appear that for some reason some basic low level firmware has become damaged and that this part of the operating system needs re-imaging - bootstrap - sort of thing? My gut instinct tells me that there isn't much wrong with it. [No hardware damage] But I need to be able to hotsynch somehow. I called Palm they will fix for either $145 or $185. thank you for your help
  • 64 Answers
Have you tried a warm reset and then tried to sync the upgrade package ? Have you considered putting the upgrade package on a SD card and running it from there (/Palm/Programs folder)?
Posted on Apr 18, 2006
  • 513 Answers
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Posted on Apr 17, 2006
Can anybody help how to flash bios into a acer aspire 3680 using the usb?
Even with the automated (windows-based) BIOS updating software, this is not a small matter. I would make certain that you need the update for a specific problem before proceeding. Also realize that a failed or interrupted BIOS update may ruin the BIOS chip resulting in a much more costly and difficult repair. Don't jump into any BIOS update without doing your homework, making sure it's necessary, and make sure you get the correct BIOS for your PC. And make sure you don't interrupt the power once it starts! That will brick your computer for sure!
Jun 29, 2011 | Acer Aspire 3680 PC Notebook
I have using msi k8mm-v ms-7142 ver:1 motherboard with amd sampron 2500+processor its audio driver is not working i download and install ac97 audio from msi site but it is asking to enable bios audio...
You have to double check the cmos or bios settings which the audio are enabled mostly on integrated peripherals inside of you bios! Tap DEL key to enter bios setup.If the audio settings are enabled other solution is to upgrade your bios firmware. You can actually download the update from MSI official website. But be careful while updating your bios firmware, be sure to download the exact model of the motherboard and you must have back up battery or UPS while performing flashing your cmos because if interrupted while flashing causes of fluctuation your motherboard will be dead set.Always remember to back up your cmos before flashing it. After flashing your cmos, install again you downloaded audio driver. The audio driver must be compatible with your operating system in order to install the driver. Hope this works for you!
Dec 29, 2010 | MSI K8MM-V Motherboard
Model Asus Eee 900A I tried to update bios and all of a sudden everything went off now no power at all, buttery is in good condition power charger is in good condition tried them on an other Eee and found...
I'm sorry but looks like the BIOS maybe damaged - you'll have to get the BIOS fixed or replaced (on the motherboard) unless it has a socket. If anything happened during the upgrade process like a power interruption, it could cause the problem. The BIOS upgrade process does an erase/write flash of firmware to its' memory. If disrupted, the firmware codes become corrupted.
Oct 29, 2010 | ASUS Eee PC 900 Notebook
Upgraded from tungsten e to tungsten t5 did first hotsync but subsequently get error message line:4038 error launching application
Hello.
From Palm Support:
When you upgraded from the E to the T5, did you precisely follow the upgrade directions? These steps include the following actions:
Did you install the new Palm software that came with the T5? Did you rename the Backup folder on your computer before you synced the T5?
If you did not rename the Backup folder you have installed system and preferences files from the E that are not compatible with the T5 and NVFS.
Advise that you hard reset to return the E to factory condition and precisely follow the upgrade procedures.
Hope this helps.
Jan 05, 2010 | Palm Tungsten T5 Handheld
How do you flash the rom on tungsten t5
Sir now you have to upgrade the software of your phone
Jun 01, 2009 | Palm Tungsten T5 Handheld
pls try these steps first
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
otherwise update rom from here
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Mar 03, 2009 | Palm Tungsten T5 Handheld
Motherboard BIOS softwere for update
The process of upgrading the BIOS on a computer is also
called "FLASHING" the BIOS.
On very old computers (486 and older) the BIOS may be
permanently programmed into read-only memory chips,
which are not flash-able, although it may be possible to
replace the chips, or re-program them using special
equipment by a qualified technician.
On virtual all modern computers, the BIOS can be updated
using new data and a special FLASH program available via
download from the manufacturer.
This is a very dangerous procedure that can destroy the
motherboard if performed incorrectly, and should not be
performed unless absolutely necessary, such as when
you computer or software will not run properly without it.
Most mother board manufacturer's (for example Asus) offer
software patches and downloads on their web site, as well
as BIOS upgrades.
Note that the BIOS is 100% board specific, installing the wrong
BIOS can permanently destroy *********** board, so make sure
that you download the correct one for your board.
Once you have the downloaded the BIOS upgrade, there are 3
possibilities:
1) The downloaded file is self-installing, either from Windows,
or it creates a boot-able diskette, which in turn contains all
the files needed to update (FLASH) the BIOS.
2) The BIOS comes with a a separate installer (.exe) which
either runs from Windows or via a boot-able diskette.
3) The existing BIOS has a "built-in" flash utility, accessable
through the BIOS settings. This utility runs at a very low
level without any operating system to self-update the BIOS
from your download binary file, located on the hard drive or
on a diskette.
This is by far the best and safest way to do the job, but only
if your motherboard and (existing BIOS) has that capability.
In any event, the first step is to visit the manufacturer's WEB
site, then go to SUPPORT or DOWNLOADS.
Find the exact model and version number of you motherboard
in the manufacturer's list, and download the latest BIOS
update, and any installation (or flashing) utilities that come
with it.
1) Follow the manufacturer's instruction exactly !!!!
2) Do not turn off the computer until the BIOS update is
complete, and you are instructed to do so !!!
N.B.
The computer BIOS is the lowest level program on your PC,
without which the computer CANNOT read the disk drives or
perform the lowest necessary functions.
If the BIOS is damaged, or
If the wrong upgrade is installed, or
If the upgrade is performed incorrectly, or
If the upgrade is interrupted or crashes before finishing,
the computer may become unable to repair itself, and
the mother-board may become permanently unusable.
(This depends on the actual mother-board and BIOS design,
and on the damage done by the failed installation)
Good luck,
Please rate my answers,
Martin
Aug 04, 2008 | ASUS P5L-MX Motherboard
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Upgrading from an earlier version of Palm Desktop
It is not necessary to uninstall your current version of Palm Desktop before you install this new version. The Install Program automatically detects an earlier version of Palm Desktop and updates the system files appropriately.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
104 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
