Question about Kenwood KDC-MP205 CD Player
Cd won't play
Put cd in tries to load then ejects it system goes back to radio
  • jesse boyd Sep 26, 2008
    Any mp3 cd i burn always get a TOC ERROR. Even commercially made one's. This make me think this Kenwood is a piece of **** as they advertise that you can play mp3's.
If its a burnt cd then it might not work with the headunit~
otherwise the cd might be scratched or something.
Posted on Sep 11, 2008
6 disc CD player won't play, eject a loaded CD or load a new CD
You may have to remove the radio and disassemble it remove the jammed CD. Unfortunately, there is no easier solution for the problem.
Aug 31, 2016 | Car Audio & Video
Cd will not eject , the face says ejecting and then goes back to playing the radio !
CD loading mechanism fault. Either a broken gear wheel or a broken loading belt might be the cause. You have to take out the CD loading mechanism from the device to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 20, 2015 | Car Audio & Video
My Ford Explorer 6 disc cd has 1 cd stuck in it and it won't eject, play or let me load other cd's. How do I get the cd out?
take the radio out and take it apart and move the sensor out of the way and take the CD out you might have to replace the CD sensor
Feb 24, 2012 | Ford Cars & Trucks
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
ERROR 03 WHEN PUSH CD BUTTON
Two solution proposed on other forums:
1. Hold 'eject' button for 10 seconds. The system should eject the cd.
2. Slide a credit card back and forth on the cd opening. Push eject, the cd should be ejected.
Hope it works.
Oct 14, 2009 | 2004 Mitsubishi Endeavor
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
Ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
May 11, 2009 | Car Audio & Video
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Car cd changer not working!
try pulling the fuse and resetting it, make shure its the +12v cont wire
Don
Dec 29, 2007 | JVC KD-S680 CD Player
Kenwood KDC-MP205 CD Player Logo
64 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
