Question about Pioneer DVR-213LS DVD±R Dual Layer Burner
No video, but audio OK
Hi, I've just installed a Pioneer DVR 213LS (SATA interface) to replace a Sony DRU710A (EIDE I/F), I also loaded accompanying Nero 8 Essentials, with its media player. i already had Windows Media Player 11 installed.
The Sony worked fine in every respect, until it had mechanical problems opening/closing its tray. Eventually it stopped readin g CD/DVD altogether, so i got the Pioneer replacement.
After installation i discovered that it would not play video component of DVDs - the audio is fine. the Windows player says it 'can't turn on analog copy protection' and says to update video card driver. In Nero player, it says it 'requires Direct Draw Acceleration, which is not available on my system'
I have downloaded a firmware update for the Pioneer . no help. Device Manager tells me everything is working OK. Windows Update can't find an update for the video card
A friend suggested trying the free VLC media player - all video and audio functions work fine with this player!
The Window player is my preferred default player (lots of different users in the family) and i would like to get it working - especially as everything worked fine with the Sony.
Any Clues? (Windows XP, SP3, Celeron 2.20, 1GB RAM)
    Novelist:
  • 116 Answers
This is due to some types of DVD's and readers like liking each other. A normal DVD can read these as the software in them is, well for the lack of terms, simplistic in the least.
Now as for the computer readers, they are much more complicated. And the software is really advanced. But, you can easily copy these DVD's using the right codecs if they are able to pass the copy right protection they have. Sometimes a DVD might not play at all, or have no video or audio. These are simply due to the codecs. I'd try updating all of the software you have, and also update your hardware drivers as well.
The reason VLC works is the simplicity. It has it's own codecs and they will bypass the copyright protection on most DVD's.
Windows XP is bad about Codecs, and the best advice I have for you right off hand is to upgrade to the newest Media Player (11), and update all your drivers. Also, install the third party drivers for the CD/DVD Drive as well. Sometimes the proper codecs are added in their driver sets.
I hope this helps you out bud. If there's anything else I can assist you with, I'd be more then happy. Like I said, it's just a simple matter of software vs. hardware.
Posted on Sep 20, 2008
    Sergeant:
  • 264 Answers
You should download the latest codecs
  • Sameer Kashyap Sep 20, 2008
    The first step i would like you to try is to download the K Lite codes from here and than check whether it is working or not.
    If it does not work that means that we are dealing with the issue with the Windows Media Player.
    To resolve the same i would recommend you to uninstall the Media Player and Reinstall the Media Player 11.0
    Steps to uninstall the Windows Media Player.
    Click Start>Control Panel>Add and remove programs
    From the list select the entry for windows media player and click Remove.
    Once it is completely uninstalled. Restart the computer.
    Steps to uninstall is simple as to download the Media Player 11 from here and install the same by following the instructions.
    This would resolve the issue than.
Will xw4300 accept compaq S6200cl hard drive
HP XW4300 Workstation Desktop PC specs,
http://h18000.www1.hp.com/products/quickspecs/12260_na/12260_na.HTML
Scroll down to you come to the bold heading -
Standard Features - Specs
Go down the chart on the left side until you come to -
Interfaces Supported
1 SATA 3Gb/s interface (4 Serial-ATA connectors), 1 EIDE interface for optical drives
One EIDE interface. That is the Blue 40-pin connector, on the right side of the Ram Memory slots. (39-pin actually)
(Right next to the Black Floppy Drive 34-pin connector, and above the 4 SATA connectors)
Compaq Presario S6200cl Desktop PC >Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=390423
Product Information > Product Specifications > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00056951&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=390423
Scroll down to the bold heading -
Hard drive
120GB Ultra DMA
It is an EIDE harddrive.
http://en.wikipedia.org/wiki/Parallel_ATA
HP XW4300 Workstation motherboard example,
http://www.ebay.com/itm/HP-XW4200-XW620-DDR2-MOTHERBOARD-358701-001-SOCKET-775-/110904128317?pt=Motherboards&hash=item19d266b33d
The answer is Yes.
Connect just the EIDE harddrive from the Compaq.
Make sure the correct jumper pins on the back of the harddrive, have a jumper cap on them to set them to Single;
OR,
The IDE harddrive model you have may Not use a jumper cap on any jumper pins, for some models of harddrives, to set the harddrive as Single.
Look up the harddrive jumper settings on the internet.
Start with the model number on the label of the harddrive.
Example; WD2500JB
Western Digital 250GB harddrive that is IDE. (EIDE)
Western Digital jumper settings for IDE (EIDE) harddrives,
http://wdc.custhelp.com/app/answers/detail/a_id/463/c/123/session/L3RpbWUvMTM1MjE4NDY3Ni9zaWQvQnoxcVF6YWw%3D
You will need a SATA optical drive now.
BIOS Setup > Boot Options > Set the first boot device to CDROM.
Install Windows disk.
Use IDE harddrive, and IDE optical drive on the same flat ribbon IDE cable?
Can be done, but usually is a HEADACHE, and MAY not work.
BIOS looks to see what drives are connected. It looks for the drive with the Operating System on it. (Windows)
Now put a disk in the optical drive. Time has to be divided between the harddrive, and the optical drive.
IF it does work; when you are using the computer, and the optical drive you will know the real meaning of Slow.
Have a SATA optical drive?
Regards,
joecoolvette
Nov 05, 2012 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
Just inherited a d410. runs XP pro. whats largest hdd I can upgrade to?
Disk-drives either have an EIDE interface or a SATA interface.
The largest EIDE disk-drive is 500 Gbytes.
SATA disk-drives can be much larger.
Check the manufacturer's web-site: http://support.dell.com
and select your model-number, and read the "specifications",
to determine whether you have an EIDE or a SATA disk-drive.
Oct 16, 2010 | Dell Latitude D410 Notebook
I bought a "My DVR Expander" to use with my DirecTV HD DVR. Does Western Digital make this expander in anything larger than 1TB? If so, where can I buy one?
Note that your DVR will treat this as "extra" storage, i.e., supplemental to its "internal" storage.
A 1 terabyte hard drive allows you to record:
  • Up to an additional 600 hours of Digital TV
  • Up to an additional 120 hours of High Definition TV
Since the largest EIDE/PATA disk-drive is 0.5 TB, the disk-drive inside the Expander must be a SATA disk-drive.
So, disassemble the unit, disconnect the SATA disk-drive, and pay about $300 to buy a "2000Gb Western Digital Caviar RE4 Raid Edition 7200RPM 64 Mb Cache 3.5 7200RPM 64 MB Cache SATA Internal HD 3 Yr Warranty WD2003FYYS".
Connect the disk-drive to its interface.
Close-up the case.
Connect your "custom" PVR expander to your DVR,
and see if your DVR will recognize the 2TB of disk-storage.
Sep 08, 2010 | Western Digital My Book Essential Edition...
Need to upgrade Sony Architect to be compatible with Windows Vist
http://www.sonycreativesoftware.com/download/updates/cdarchitectfamily if you are using 5.0 you will need to upgrade from the web site above, to 5.2 then do the 5.2 update as this is the Vista patch,
Apr 03, 2009 | Sony CD Architect 5 (sf2cdr5000) for PC
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
Oct 12, 2008 | Pioneer DVR-213LS DVD±R Dual Layer Burner
How to install second harddrive
I could explain it buy a video may give you a better explanation.
depending your hardware configuration you should have either a parallel interface or a serial interface (the type of connection the hdd has to the motherboard, most of the sort of old systems may have an IDE/PATA/ATAPI/EIDE interface connected to the motherboard) as opposed to a serial interface.
http://ca.youtube.com/watch?v=BvvM2Ao4Jpk
for serial interface (SATA) this video should give you an idea.
http://ca.youtube.com/watch?v=kCgFYNLzn18
Sep 28, 2008 | Computers & Internet
Pioneer DVR-213LS DVD±R Dual Layer Burner Logo
65 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
