Question about Akai LCT3201AD 32 in. LCD Television
Akai LCT 2701TD wont power on, need help ASAP!
So my TV went off two days ago ... before then, i had never ever had a problem with it ... until yesterdat when i turned my TV on, and after a minute, it went black ... even the standby red lil light went off ... i thought the problem was where it was connected so i switched, and still nothing ... i've tried the power on/off switch that is on the left, and the power on switch on the right ... and still nothing ... i need help!!!
  • 2,334 Answers
In about 95% of the time if the TV is not powering up, the power supply needs to be replace or repair. I've repaired a few hundreds ot these power supplies.
Let me know if you need further assistance.
Posted on Sep 16, 2008
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Our power went out for a few minutes yesterdat and since then our refrigerator and freezer aren't working. What could cause this problem? -Thanks.
first of all I would check the outlet where your fridge is plugged in to make sure the power surge didn't affect it. maybe plug in a lamp. if it is ok, and the fridge will not start at all, i would check the relay/overload on the compressor as it may have been compromised by the power surge when the power came back on. these components start the compressor which in turn starts the cooling/freezing of your fridge. hope this helps.
Oct 13, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
HP Pavilion md5880n TV new lamp, left red light
I had the same problem the bulb was good but no power it was the transformer 975.00 under warranty from brandsmart. It worked for 90 days then the mother board went bad it cost 1000.00 they won't fix it .they gave me 1098.88 for a new one .Im gonig to sell mine for parts . I also have the stand for my tv also .
Jul 11, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Akai LCT3201AD 32 in. LCD Television Logo
146 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
