Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Viking all refrigerator
I am having problem with the recently bought Viking all refrigerator and a Viking Ice Machine.  The Viking all ref is sweating inside.  Boxes inside the ref are getting wet.
  • gc00001 Nov 05, 2008
    I agree. We've had nothing but problems with the VIking stainless we bought only 2 years ago -- sliding trays pop out constantly, handles broke off without much stress, ice machine no longer works, water leakage draining on the floor (fixed twice now), etc., etc., etc.
    Buy a Subzero instead.
  • Anonymous Mar 30, 2014
    It was bought in 2007
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Posted on Sep 28, 2008
Not dispensing ice
Try turning it off for 12 hr's. Buy the 5 yr. warranty on all ref. with ice maker
May 21, 2014 | Viking 42 in Built In Professional...
Refrigerator sweating
it is probably set too cold and the defrost cycle is not enough to get rid of all the humidity that is generated. try moving the control to warmer temperature.
Oct 02, 2013 | Viking Refrigerators
"Hi, I have a questions
It seems you will need a service technician again. Be sure you got a warranty if you agreed to service your refrigerator. If you use the refrigerator correctly it will never go bad for less than a year and call for service repair. But if you definitely used it correctly, chances are the refrigerator you brought have a factory defect.
I hope my advice help you.
Jun 15, 2011 | Refrigerators
This is the 2nd time I have had the same problem. After one year the ice maker stops making ice and heats up inside the unit. Viking replaced the unit last year and now one year later I have the same...
could be numerous issues that stop machine from working
but as its outdoors i would remove condensate drain pump
and make it a gravity drain
if drain pump fails will shut down power to unit
Aug 28, 2017 | Viking Refrigerators
WHY IS ICE BUILDING IN THE AREA WHERE ICE EXITS MACHINE (BOTTOM) & INSIDE DOOR EXIT? THEREFORE, INTERFERING OPENING THE DOOR. I HAVE REMOVED SEVERAL TIMES & IT HAPPENS AGAIN?
this ice is coming from the air after you open the door of your ref.the cold air goes down and the hot air enter to your ref. the hot air is highly on humidity that cause of building of an ice. try to fix your door maybe the doorgasket isnot align that has leakage of cold air on your ref . avoid too much door openings. or try to defrost your ref. weekly.
Feb 13, 2011 | KitchenAid Refrigerators
Fog and dew dripping in ref
It may be high humidity of the air outside of the refrigerator or you are storing highly humid things inside along with the settings of the fridge.
Jun 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Inside sweating and turning to ice
sounds like condensation. place a film of vasoline on mating surface of gasket and make sure door is shutting good.
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a ge pds20mcr bottom freezer ref and have a foul odor coming from the bottom of ref.
If the odor is only present from the bottom of the fridge, and not inside the freezer or when it is shut, it is most likely spoiled something. Put everything in a few coolers, cover with ice and close up, spray out the fridge with some cleaner and let the freezer defrost if there is ice buildup on racks or surfaces. After the fridge is clean, I suggest using a box of baking soda to keep odors out of your fridge. Arm & Hammer recommends replacing these boxes every 30 days, but I've had mine in there for 6 months or so and it helps.
Dec 03, 2009 | GE Energy Star PDS20MCR Bottom Freezer...
Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Jan 06, 2009 | Viking Refrigerators
Combo75 icemaker
hi,
make sure you have enough stock in your ref. for the supplied water for ice maker not to be frozen. or if sometimes you have less supply inside your ref., then put some gallons of water and stock it in your ref. and in your thermostat steady to the lowest setting.
Oct 11, 2008 | U-Line Refrigerator Ice Maker
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
480 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
