Webcam not working
My webcam doesn't work on my Gateway PC. It worked before. I receive the error "Cannot open file C:\Program Files\Camera Assistant Software for Gateway\corona\BG1.bmp". I've tried to uninstall the software, but I get the error "setup.exe has stopped working". Any suggestions would be greatly appreciated.
  • khahinh Oct 14, 2008
    My Gateway T-1631 w/ builin webcam, but today when I turn it on the computer say:"EAccess Violation" and want to re install the Camera
    Assistant Software " Please, tell me what to do ? Thank You
    Henry
Acer crystal eye webcam runtime error problem
Try reinstalling your camera driver and application program.
Mar 28, 2012 | Computers & Internet
Hello. yes i have the Gateway NV79 and it is just working great but i have a built in camera in it and whenver i look to find on the search programs and files buttons i can not find it. i wanna use the...
hi there! :)
if your computer is not detecting it maybe the webcam driver is not yet installed. try to download this driver just copy and paste the link on the addres bar then install it see if it works! :) goodluck :)
http://global-download.gateway.com/GDFiles/Application/Camera/Camera_Chicony_1.7.85.1207_W7x64_A.zip?acerid=634103558563805439&Step1=NOTEBOOK&Step2=NV%20SERIES&Step3=NV79&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G
Sep 25, 2011 | Computers & Internet
My Gateway Windows 7 NV5929u laptop's built-in Video Web Camera doesn't work. All it does now is pop up the following message whenever I try to open it: Cannot open file C:\Program Files...
The file it's saying it cant find is a simple image file, most likely a picture used for a background or some other part of the webcam softwares interface. The first step would be to go to the location it's mentioning and make sure the file is in fact missing. If it is, you can check the recycle bin to see if it has been accidentally deleted. If its not there, then the next option would be to re-install the webcam software.
The webcam software for the gateway NV59 series can be downloaded here : http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2379
hope that helps.
May 30, 2011 | Computers & Internet
How do i turn on the webcam on my laptop?
Hello jenna_foster,
If you don't have a crystal eye webcam shortcut on your desktop then do the following:
•Click Start (lower left-hand of screen)
•Select Run
•Copy and paste this in the Run window (include quotation marks):
"C:\Program Files\ACER Crystal Eye webcam\Acer Crystal Eye webcam.exe"
•Click ok
The Crystal Eye webcam will become activated
Have a great day,
martyshaw152
Feb 10, 2010 | Acer Aspire AS5520-5537 Notebook
Can't Acess My Chicony U.S.B Webcam, no icon, ALWAYS WORKED
try to start the interface of webcam using :
1. start menu > programs > chicony webcam
2. open C: drive > program files > chicony webcam and double-click "chicony.exe" file
3. in the properties, check "show in task bar"
Dec 31, 2009 | Computers & Internet
How i can download a4tech pk-336 webcam without installer. the suggested solution doesn,t work...
Thank you for posting your question.
To obtain your drivers software for this particular device do the following.
Step 1. Go to the A4Tech website and click on web camera in the Quick Product Locator section.
Step 2. Select ViewCAM.
Step 3. Click on the PK-336MB image.
Step 4. Click on the Download Driver tab.
Step 5. Click on the Driver for PC button, and this will prompt you to download the driver software in the .rar format.
Step 6. Extract the rar file onto your desktop.
Step 7. Open the extracted files and double-click on the Setup Program. This program will walk you through installing the driver files and software. Once completed, you will be prompted to restart your computer.
Step 8. After you have restarted your computer and have logged in, plug the webcam into one of your computer's USB ports on and the device will be recognized and the drivers will be installed.
Dec 23, 2009 | A4tech PK5
Gigaware webcam installation not working
Remove the CD, then go to the program files folder and remove the folder that applies to this device. Remove the device from the USB port.
Reboot the PC.
Reinstall the software before you attach the webcam to your PC. Only attach the device when directed by the installation program, or after you have fully installed the software.
It's a pain in the ****, but reboot after you finish installing the software and then attach the device. This will allow the device manager utility to fully recognize the device and apply the appropriate drive files.
Rich
Dec 15, 2009 | Radio Shack VGA PC Camera Webcam
Webcam support
Try to login to windows messanger if you have else some chat programs like yahoo,skype or google, followed by try making a video call and it'll let you know whether your webcam works or not.
But if you want to see your webcam programs,
click start - all programs - search for the name(Web cam manufacturer)
or
open my computer - open c:\ - program files - search for the webcam manfacturer.. It should be there..
If you still dont find, let me know.
Hope this helps !
Thanks !
Oct 06, 2009 | Computers & Internet
My webcam won't work on msn
download the new windows mesenger here http://messenger.live.com/ this would be easyist to fix the problem. or 1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Jun 11, 2009 | Sony Computers & Internet
1828 Error
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Aug 17, 2008 | Radio Shack VGA PC Camera Webcam
Computers & Internet Logo
643 people viewed this question
David Payne
David Payne
