Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave jvm1640cj
Our micrwave has just started acting up. right now we can't close the door because it turns on when I do. It doesn't matter what buttons we push it will not shut off. And the turntable isn't turning during this time. WShat is the problem?
  • Anonymous Nov 26, 2008
    I have the exact same problem...Have tried many of your remedies offered but to no avail...Do you have any other suggestions.
    Waiting. for help!
  • jhtiffin Dec 24, 2008
    I accidently hit the bottom hinge on my microwave door now it comes on everytime I close the door. The little microwave symble does not come on so It is not heating. After several attempts I can push up on the door and close it hard it will eventually turn off, untill someone comes along and opens it again.
  • GE Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, a misaligned door hinge, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 16, 2008
My microwave needs a fuses,it does not heatmy food.
Posted on Dec 18, 2008
No heat from my JVM1640CJ GE microwave. Fan, lights work fine. Unit is less than 5 years old.....I've read some posts on this site - could it be a bad door switch? chip
More than likely it's the magnetron and/or diode, chances are it may still be under warranty. Online owners manual states 5 year warranty on magnetron. Part only, service call and installation not included. Diode not covered. They require serial number, and will let you know if it's still under warranty. Installation appears to be simple, UNPLUG MICROWAVE THEN MAKE SURE YOU DISCHARGE CAPACITOR. INJURY OR POSSIBLE DEATH IF NOT DISCHARGED PROPERLY. Google how to install magnetron and discharge capacitor. It will save you approx $ 250 - 300 doing it yourself. Hope this helps. Be Safe
Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
"door error", "start?" - When
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a spacemaker 11 and it says lock and does not do anything!
I had a poblem with my GE Micrwave and solved it (?) by unplugging it from the outlet for a few minutes and the replugging it!
Nov 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
135 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
