Question about Altec Lansing ACS 295 Computer Speakers
Altec Lansing ACS295 Sound Control Dial
Slowly the sound control dial stopped working on our ASC295 right speaker. It's a top mounted dial, and the part number attached to the chip board is hard to tell read as I can't find a magnifying glass. If there's any other details that I'm leaving out let me know. Thank you in advance.
PILOTE DE ALTEC ACS 295
Posted on Jul 22, 2008
Check your connector on the back of the subwoofer. Your control pot is feeding clock signals to the control chip in the subwoofer box circuit board. Better yet get rid of the connectors and solder the wires on the pc board. If that doesn't work, the controller chip on the pc board has gone bad.
Posted on Jan 08, 2007
    Novelist:
  • 130 Answers
My sugestion would be to use windows volume control. Control pots are mechanical and they will eventualy fail. It sounds like you have a dead spot on the control and it needs to be moved to a spot on the control pot where it can make better contact. I would sugest to turn it about halfway, then use the volume in windows. This cant fail since its all done with the opperating system. Even if you get another set they will eventualy do the same thing.
Posted on Apr 18, 2006
    Champion:
  • 277 Answers
Hi first buy a conductivity spray and spray on the dial and inside it if this wont help then just solder a knob which will fit good luck
Posted on Apr 17, 2006
HOW DO I GET THE ALTEC LANSING SUBWOOFER MOD. NO.ACS295 TO WORK WITHOUT THE SATELLITE SPEAKERS?
You would have to design and build a box that contains the controls normally housed in one of the satellite speaker enclosures.
Nov 19, 2017 | Altec Lansing Audio Players & Recorders
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
My speakers used to work and suddenlly stop then beganto where somtimes when i longed on they worked and other they would all i hear when i turn them up is static and now my compouter is saying the are no...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 13, 2010 | Altec Lansing 2100 Computer Speakers
Very low volume coming from speakers
i have exact same problem i think its got something to do with volume controller on front right speaker damn shame as the sound was awesome
Jun 02, 2010 | Altec Lansing ADA745 4 Speakers
I had a dell 2700 computer working with altec asc295 speakers and the dell crashed. i connected the acs295 speakers to my other dell 4700 and they don't operate.
First the easy things. Are you sure you plugged the speakers in the correct socket.
Are you sure the speakers are plugged in and the power switch on.
Is the volume turned up on the speakers.
Is the volume turned up on the computer, Not just the program you're running but also from the tiny speaker icon at the bottom right of your screen.
Have you checked the sound card (if it's not a built in system) is correctly inserted.
It sometimes helps, if it's a plug in card to remove the card, clean the card's contacts with clean white paper and then plug the card back in.
Check the card is actually working by plugging in another set of borrowed speakers.
Ensure you have drivers loaded for the sound card.
Check the system manager in your control panel and make sure there's no conflicts.
BE CAREFUL WITH THIS ONE......
Grab an almost flat AA or AAA battery and connect intemittedly one lead of the speaker to one end and the other wire to the opposite end of the battery. If you hear a clear crackle in time with the touching of the wires then the speaker should be OK. If you have a multimeter, switch it to OHMS and check the speakers on it's low setting. It should register around 4 Ohms. Even on high settings the meter will show a bunch of zeros or if it's a meter the needle will swing right across the dial.
If all these pass then I would be checking with a substitute sound card. But this would involve loading the appropriate drivers too.
Good luck.
Apr 06, 2010 | Altec Lansing ACS 295 Computer Speakers
Computer not seeing Altec Lansing BX1020 speakers
go to start>settings control panel> click on system then click on device manager. Make sure that everything is working properly then in control panel click sound. if that is all working. Make sure you have the speakers connected in the right spot. You may also want to try the speakers on another computer to isolate exactly what the problem is.
Thank you,
lee
Nov 10, 2009 | Altec Lansing BX1020 Computer Speakers
Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Sep 22, 2008 | Altec Lansing Multimedia Computer Speakers
1,118 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Level 1 Expert
Don Hart
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
