Question about Cameras
I need a lens for my cannon digital - Cameras
    Genius:
  • 2,985 Answers
Model Number?
Are you talkng about a changable lens in an SLR model
or a broken camera?{if it is broken then you will not get it repaired - new camera time]
Go to Canon Web site
Visit your local store
Posted on Sep 11, 2008
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
NIKON LEN /CANNON LEN
Search ebay or a search engine like Google with nikon canon lens adapter as the entry. There are two kinds. One is mechanical (cheaper); the other has some electronics (expensive). Mount the adapter on the lens then mount onto camera. See www.kenrockwell.com/tech/nikcan.htm
Aug 21, 2009 | Canon Cameras
Cannon sx100: displays lens error, restart camera
If your lens received impact damage it will need to be replaced. This is about a $150 bill at Canon. One thing that can happen is the flex cables that attach the lens to the camera system board may have come loose. You will have to have the camera opened by a qualified tech to see if this may be a solution.
Jul 02, 2009 | Cameras
The lens on my Cannon SD sure shot wil not close
Lens errors are fairly common for all digital cameras. Usually it's sand (be careful at the beach) or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
