Question about ASUS (P4BGV-MX) Motherboard
Pc is not booting and no display in monitor
I have asus p4bgv-mx motherboard and p4 processor. my pc is not booting no beep sound. it produces beep sound when ram is removed.processor starts running once i switch on the power but ater few seconds cooling fan stops and starts again. my monitor and cords are in good codition its working with other cpu. HDD is working well in another CPU.
  • sjohnkennedy Sep 12, 2008
    i tried resetting cmos and i changed it with a working ram still its not working
  • sos3 May 11, 2010
    Can u replace the BIOS?
  • 67 Answers
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Posted on Sep 12, 2008
  • Kirk Philipson Chan Sep 12, 2008
    Hmm, that's a hard one. Try going back to the basics. But before that, make sure you are wearing anti-static band and you have the manual for your motherboard so you wont get lost. Remove everything else except one working RAM, and processor. And try using the built-in video if available. Plug in the built-in beeper, and power button. Insert the motherboard power, and the 4 pin additional power. Try and see if it powers on with this setup. When was the last time you were able to turn this setup on? It could also be that the four pin extra power for the CPU was not connected or the CPU is not supported by the motherboard.
I cant get display in my asus p5gz-mx motherboard . monitor is ok. pc is on but no display.........
If you are using a flat screen monitor with multiple inputs be sure that the monitor setup is selected to VGA. If that is okay try repeatedly hitting the keyboard key for entry to the BIOS Setup when you reboot. If nothing appears try installing a video card. Check your motherboard over carefully to see if anything is loose or not installed properly like the memory or any added cards. Did the processor come installed or did you install it? Is it a supported dual core Intel processor? Do you get any beeps when you boot up?
Sep 18, 2011 | ASUS P5GZ-MX Motherboard
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Good morning ihave a pc which suports a asus mother board unfortu
Hy, go to http://support.asus.com/download/download.aspx?SLanguage=en-us
Select : Motherboard, Select: 478, Select : P4BGV-MX
Click go, then select your operating system , and download all drivers needed.
Apr 04, 2009 | ASUS (P4BGV-MX) Motherboard
500GB SATA with SATA to IDE adopter
You have crossed wiring somewhere
Nov 06, 2008 | ASUS P4GE-MX Motherboard
ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Jul 03, 2008 | ASUS P4SP-MX Motherboard
Won't boot
usually long beep is RAM
Apr 01, 2008 | ASUS P4S800-MX Motherboard
ASUS (P4BGV-MX) Motherboard Logo
267 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
