Question about Sony CCD-TRV238 Camcorder
Sony Handicam TRV30 - Loose Lens
My lens appears loose on my trv30. The left side of the lens appears to be loose. A 1/16th inch gap opens up easily. The camera still works fine. The TR238 looked like the main lens was similar. Is there a way to tighten it up or is something busted?
  • Fred Goll Apr 17, 2006
    Now posted on TRV30 problem site. Appears to be housing around lens that you would add filters or sun shade, not lens.
    Champion:
  • 277 Answers
Hi sounds like the screw that holds the ccd is gone but its inside you say it all works good....? put a SMALL!!! drop of "superglue" it will hold nice good luck
Posted on Apr 17, 2006
No driver for sony handycam trv30 using windows 7; can't find a driver that will work with firewire 1394
usb streaming is not supported by your new windows OS,reason usb driver is not available. for ilink or ieee1394 connection it should be a plug-and-play connection. no setting in the camera enables or disables ilink output and an ilink driver for the camera is not needed to support this connection (not unless you need to update or reinstall your ieee1394 device driver to get it to work). check this solution link: http://www.kb.sony.com/selfservice/microsites/search.docmd=displayKC&docType=kc&externalId=C86798&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=157560925&stateId=1200%20157576924
hope you can get to establish connection.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
DCR-TRV30 Internal clock battery is end of life. It will not charge overnight or hold date/time set information between main battery changes. There is no replacement information in the user manual. Where...
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
May 23, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
Camera flashing error E:91-01 on movie camera model DCR-TRV30
This worked for me: With camera power on, push RESET (located left of the rec button in the main panel).
Apr 02, 2009 | Sony Handycam DCR-TRV30 Mini DV Digital...
No display on flip out screen
I have a Sony DCR-TRV30. Your camara is probably similar. On the bottom left outside corner of mine, there are two buttons, labeled "exposure" and "program AE," and a small thumb wheel above them. Set the indicator to "camera" and open the screen. Push the "exposure" button and a light grey rectangular screen with a minus sign on one end and a plus sign on the other will appear near the top left corner of the screen. Rotate the thumb wheel so that the small black square in the rectangular screen will move from the "+" side towards the "-" side while the image on the screen gets darker.
Jan 04, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I need the DCR-TRV30 driver
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV30
go here and click driver download
Dec 17, 2008 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony Handicam
dear kwilsey,
just turn on your camera and look at the front side of camera.i.e just note tat your lens shutter is opened. if lens shutter is opened then prob is with your ccd devices. Contact the nearest authorised service centers.
Sep 05, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony dcr trv30 zoom inout problem
Wow, your camcorder is ill... sounds like an issue with the controller chip, This issue can be caused by all kinds of things, like moisture in the enclosure etc... I think this will have to be professionally serviced.
Oct 03, 2007 | Video Cameras
Loose Focus ring assembly
IF YOU TAKE A LOOK AROUND THE FRONT OF YOUR CAMERA THERE ARE SEVERAL SCREWS, ABOUT 4 I THINK,
1) 1 ON BASE
2) 1 ON THE LEFT LOOKING AT FROM THE FRONT
3) AND 2 INSIDE THE FLASH CASE
REMOVE THESE SCREWS AND THEN YOUR FOCUS RING AND SOME OF THE CASE SHOULD COME OFF
INSIDE THE FOCUS RING YOU SHOULD SEE 3 SREWS IF NOT CHECK THE CAMERA TO SEE IF THEY HAVE FALLEN INSIDE,
IF NO JOY YOU CAN REPLACE THE 3 MISSING SCREWS AND PUT IT ALL BACK TOGETHER
SWEET
DAVOS69
HOPE YOU DONT MIND BAD SPELLLLLING.........
Aug 25, 2006 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony Handycam TRV30 - Loose Lens
hi sounds like the screw that holds the ccd is gone but its inside you say it all works good....? put a SMALL!!! drop of "superglue" (3 sec glue) it will hold nice good luck
Apr 16, 2006 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony CCD-TRV238 Camcorder Logo
73 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
