Question about Mitsubishi WS-55807 TV
TV loses pictures shortly after turning on
The tv will lose picture after being turned on and the picture can sometimes be brought back by giving the top of the tv a hit but eventually goes off again shortly after. need help identifying the problem
It looks to me a loose solder, or loose contact joint somewhere in the video section or at the CRT board itself. Try also to resolder jungle ic pin, extra care must be observed in soldering this IC, see to it that no voltage is present before doing this,it may damage the ic.
Hope this idea will help.
Posted on Sep 11, 2008
My son brought me a T.V for Christmas i am constantly having problems the Picture is constantly breaking up and losing the signal can someone advice me please
What kind of tv programming do you have? Antenna, Cable, Dish? Most of the time if the picture is breaking up it will be the signal from the source, not the tv.
Mar 12, 2014 | Televison & Video
My Pillips 42" TV works
Is this a plasma TV? I have worked on several of these. Please provide the model number so I can better help you.
Mar 23, 2011 | Philips Televison & Video
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
Jan 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Fading and losing pictures
If your TV has more then 1500-2000 hours of usage chances are the power board is starting to fail due to the amount of heat that the parts are expose to when the TV is on. There seems to be a high failure rate on power supplies due to overheating.
The solution to get the TV working properly will be to have a new power board or repair the on inside your TV.
Let me know if you require further assistance.
Jul 26, 2008 | iLO 3200 32 in. LCD Television
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Picture problem
Since it is 9 years model definetely loose contact and flux corrosion is there in wire connector and pcb also. Make one general service. Prolem solved.
Aug 23, 2007 | Toshiba CF35F50 TV
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
May 31, 2006 | Toshiba 36A43 36" TV
Mitsubishi WS-55807 TV Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
