Question about Video Game Consoles & Games
I have a ps3 i had it hooked up to a 46" samsung 1080p, then i drove 2 miles with ps3 in box and hooked up to a mitsubishi 1080i 52" tv and i could only see part of the ps3 screen either in game or on just on ps3 main screen menu... when i tried to use just the regular av cables that come with the system i couldnt get anything... please help me..... contact me @ subject ps3 help.... thanx
  • 42 Answers
Tv's are difffrent and the ps3 knows that.
You need to adjust the settings on the ps3 or on the tv.
It still works at your home correct?
If so its just a compatability issue with your ps3 and trying
to get it to work on another tv.. It thinks its still 1080p when its actually 2 miles down the road on a 1080i
Go to your system settins on your ps3 and change them to work on a 1080i
Good luck
And if you have anymore questions or if this dosn't work, please feel free to ask
Posted on Sep 11, 2008
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv the size- now you need to set the all resolutions that the TV supports, since it is a is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Trying to connect PS3 to Samsung HL-S4676S tv using HDMI cable. I get message saying mode not supported
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
Oct 09, 2010 | Samsung HLS4676S Television
PS3 display problem for multiple TVs
try to do a simple reset it will reset your video settings just turn it off then hold the power button then KEEP HOLDING until it beeps 2 times then it should come up note: it will not delete any of your data
Mar 04, 2009 | Mitsubishi WD62627 62" HDTV
No picture/intermitten picture
I just got through explaining this to someone else - the HDCP encryption system that Philips uses is not future-proof - you will continue to have this problem as long as you use an HDMI connection with a Philips TV. My advice, which you can take or leave, is to use Component (Red, Green and Blue) cables. you won't get 1080p, but you will get 1080i, which is pretty close.
-Tha Mp3 Doctor
Jan 16, 2009 | Philips 52 In. LCD HDTV
Installing PS3 with HDMI
there must be a HDMI option in the picture settings on the tv and select 1080i or 1080p in the ps3 video output settings
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Just bought, everything coming in at 1080i not 1080p
the xbox 360 does not brodcast at 1080p and no tv channals are in 1080p yet. Blu-ray and HDDVD is the only thing in 1080p yet
Jul 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Will not display 1080p from a Sony ps3??
Connect your PS3 through the HDMI 2 port on the TV and as a PC under the tv settings. Then auto setup the tv on the PS3 and it will now see it as 1080P. It will give you some error message whenever the PS3 is first turned on but it will work. Hope this helps everyone.
Jan 20, 2008 | Mitsubishi WD62627 62" HDTV
Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
