Hello again,
I found your manual. If you like to get it, go HERE. This is what it says about "SUDS" action:
"SUD" (Suds Routine)
When excessive suds are detected, a suds routine
automatically starts. This routine removes extra suds and
assures proper rinsing of your garments. "SUD" is displayed
during rinsing to inform you that Suds Routine was activated.
Use only HE (High Efficiency) detergents.
Near the bottom of the troubleshooting page, it gives this for errors:
"F" Codes other than F20, F21 and F22
Select STOP twice to cancel the cycle. Select DRAIN & SPIN
if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
It doesn't specifically state what "F35" is, so I can only suggest these steps, and see if this solves your problem. If it doesn't I would be inclined to believe that there is a problem with a part, which would probably be serviceable by a tech from Sears or their partner service company.
Hope this clears it up for you.
Please rate and comment. Thank You
Joe
Could you look at the label, probably on the door or on the back and give me a 8 to 12 digit number that is the model no. please, that will make it easier to track down the manual to help you better
Thanks,
Joe
Thank you for the response. Model no For the above Kenmore Washer is 110.47789701 and the Ser. # CSW0710697.
