Motorola Mobility RAZR V3 Logo
Posted on Sep 11, 2008
Want to eliminate lengthy pre-recorded greeting/instruction
Prefer to have only my greeting - not the: if you'd like to page this person junk. I'm told this is possible but have scoured the manual and do not see how to change it. Thanks.
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Sep 11, 2008
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
11250
Points
87
It will not be in your manual. This can be done either through your provider or through your voicemail depending on who your provider is. Hope this helps.
The answering machine out going message is a pre recorded message with a British lady's voice. We have our company message recorded as per manual, what are we doing wrong?
Marianne
If a personal greeting has not been stored, the pre-recorded greeting is played.
unfortunately the user manual does not say how to store a greeting but I am assuming you have to press 2 to accept the new recorded greeting and hopefully it will store the recording as it is not really explained in the user manual on the process on how to store a greeting.
ftp://ftp.panasonic.com/telephone/om/kx-tg4500_en_om.pdf
page 60
Are you pressing two (2) to accept the greeting after you record it ?
5helpful
2answers
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
1helpful
I lost manual. I need to know change message when will be out of town answering message.
announcement.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
It tells me that I cannot re record greeting - it says unable to fix now
what this simply is that your panasonic phone has been over power by power supply what you are to do first of all put off the phone for some time then put it on again after it most has relax it self then apply the below instruction to reprogram the greeting message on your panasonic phone again
Several Panasonic telephones come with a built-in answering machines. You can leave the telephone as is and let your callers hear a message pre-recorded on the device by Panasonic, or you can personalize your phone with your own greeting.
Instructions below.
  1. Press "Getting Rec" on the base unit.
  2. Press "Getting Rec" again within 10 seconds after you hear the pre-recorded message, "To record greeting, press record again."
  3. Lean in so you are within eight inches of the microphone on the unit, and wait for the long beep.
  4. Record a personal greeting lasting up to two minutes after you hear the beep.
  5. Press "Rec Greeting" or "Stop" after you have finished recording your greeting.
  6. Record your greeting again if the base unit displays an "E" and beeps six times in a row.
  7. Press "Greeting Check" to hear the greeting you recorded.
Hope this help?
Thank you and thanks for using fixya.
3helpful
How do i change my vociemail message for the Dect 6.0?
Reording a Personal Greeting Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting.
To keep this greeting: Do nothing.. To switch to the other greeting: Press 6 while the system is playing the current greeting. Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last greeting you hear is used as the current greeting.
Deleting Your Personal Greeting You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous section to switch the greeting.)
While the personal greeting is playing, press 4. The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
7helpful
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
68helpful
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
8helpful
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
3helpful
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
