Question about Samsung SV5000W VHS VCR
The power comes only in a standby mode
Just completed my Diploma in Electronics and want to do a lot of practicals. My samsung SV5000W VCR power only in stanby mode. I do not have a full power. I removed the mechanical part and see if I can have a full power but it still the same. I have try all the troubleshooting technics I know but can't get the power back in full mode. Can I get any assistance please?.
    Novelist:
  • 130 Answers
VCRs are both mechanical and electrical. Mechanical things usualy fail in these first because of wear and heat. They use this thing inside called a mode switch. What it does is makes contacts to different sections of the unit depending on what mode its in. These are common to fail because they control motors and motors can draw more current as they get old. They also use gears that are timmed. If the timming gets off they can be tricky to reset. It sounds like the mod switch has a bad spot in it and when its in a certin mode its not making contact to the section with no power. Once the mode switch gets to a different point the contact is good and power is fine. The mode switch is usualy under the mechanical section near the capstan and the drive gears. Some times its in the back near a motor with a worm gear. You can clean them with a pencil eraser
Posted on Apr 18, 2006
    President:
  • 3,130 Answers
When you say in standby mode??? do you mean that not all the voltages are there?? Do you have a schematic for this?? as your gonna need it unless your familuar with the curcuitry and its operation. You get a manual and start at the output of the power suppys and whats supose to be always on and only switched power?? write back Please if you want more assistance and if you copy the power supply schematic and post it here I will assit you with your repair.. you can get a print here at the i# or directed to it. 1-800-SAMSUNG good luck
Posted on Apr 16, 2006
Stopped working, cannot even turn it on and casette is still inside. Please help
The vcr has a power supply problem, the repairs will run the cost if not more than a new machine, if the tape is precious and you want to save it, the top will need to come off 2 to 6 screws to access the cassette tape, sometimes you can manually unload it by turning the gears towards you on the side of the basket, but if the tape is spewed or you are not sure how to proceed take it to a shop to have them deal with it.
Feb 14, 2011 | Samsung SV5000W VHS VCR
Sound but no picture on the vcr
Do you have a picture with just normal playback of VCR? If the answer is no, then it sounds like the head might need cleaning. Use Servisol video 40 see image below:
Jan 24, 2010 | Samsung SV5000W VHS VCR
VCR can not be turned on, no any light on. Tried to unplug and plug on again - no result.
The problem has been solved. The failed electrolytic capacitor (1000uF x 16V) in the power supply circuit was found. The VCR was functional after the failed capacitor replacement. This filter capacitor needs to be high ripple current part, so, hopefully the new part (with unknown ripple current capabilities) will work fine.
Jan 09, 2010 | Samsung SV5000W VHS VCR
Samsung SV-5000W VCR. Voltage regulator?
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Jan 04, 2009 | Samsung SV5000W VHS VCR
Tape stuck, no indicators lit
check the tip in my profile
Sep 01, 2008 | Samsung SV5000W VHS VCR
NO POWER TO THE UNIT SV5000 VCR
If you have some tech savvy and a voltmeter, you could check the power supply voltages. This circuit is likely in the close vicinity of the fuse. On the output side you should see a +5 volt, +12 to 15 volt, and perhaps a -35 volt (approx). The +5 supplies the logic circuit, +12 the motors. If these voltages are missing, or way out of tolerance, you will have a dead unit. A frequent cause of problems in the supply is bad electrolytic capacitors, especially in the older units (Panasonic manufactured rigs, late '80s/early '90s). Possible values on these capacitors: 2200MFD/10V 1000MFD/16V and several others. Replacements can be supplied by MCM electronics, Mouser electronics. I use the Panansonic FC series from Digi-Key Electronics. If this is a high dollar > $250 VCR, it might be worth service center repairs. If not, then it is a disposable (unfortunate, but the way it is with most modern electronics).
Sep 30, 2007 | Samsung SV5000W VHS VCR
Tracking problem
Suggestions: 1. Do a "reset" by unplugging VCR for 30 seconds or so. Doubtful to fix- but worth a try. 2. Pull the top cover, load a tape and play. Does the tape seem to wander up and down across the video or control heads? If so, this is a mechanical problem- perhaps a tape guide is broken. 3. Electronic problem: If this is the case, probably trash the unit unless unit is a high dollar ($250 or up). VCRs (like most other consumer electronics) are throw away items these days.
Feb 18, 2007 | Samsung SV5000W VHS VCR
VCR Samsung SV-5000W
You should take off the top cover with the set unplugged and see if there is a main fuse that popped. If there is, put in another fuse,. If that blows, then your going to need to have the power supply in this unit repaired. Good Luck
Dec 28, 2006 | Samsung SV5000W VHS VCR
Doesn't power ON
If you have no indication of power at all,(no lights,no display)the fuse is the first component to check but the vcr has be unplug from the wall when you remove the top cover and remove the fuse to check it.Be carefu.
Sep 25, 2006 | Samsung SV5000W VHS VCR
No power
Well first thing you need to do if you know how to troubleshoot the power supply is to get a service manual or a schematic diagram. Then go from the front to the back as some techs start from the end of the supply to the front.. To each his or hers own I guess. Not much to tell as these vcrs have been very reliable and I havent gotten one in yet for service . sorry Good Luck
Apr 08, 2006 | Samsung SV5000W VHS VCR
Samsung SV5000W VHS VCR Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
