Question about Pinnacle Video Transfer
Trouble with audio on pinnacle video transfer
When I capture video with the pinnacle video transfer, the audio tends to have a kind of "metallic" sound in the background (similar to a bunch of birds chirping). The noise seems to be enhanced when I use pinnacle studio to edit the video. Is there any known fix or work-around?
  • 3 more comments
  • Anonymous Nov 19, 2008
    I have the same exact problem. At some point that metallic sound you mentioned suddenly out of no where appears in the video and it's annoying specially when there is a beautiful music playing in the background of the video. Pinnacle Studio to fix this? Does Pinnacle Studio support MP4?
  • Anonymous Jan 26, 2009
    Mine makes a buzzing audio sound and its delayed.
  • pikerosa Jan 28, 2009
    I get a buzzing sound with my audio and the video does not sync with the audio. Has anyone found a solution?
  • Anonymous Feb 11, 2009
    The sound doesn't fit with the film! And i have the buzz sound to! I am sick and tired of this and have tried everything! I have the correct setup. Does anyone know the answer of my problems
  • videodj Feb 23, 2009
    I have the same metallic buzz all the time I record, anyone found a fix yet?
I have had this problem several times, and there is a simple solution that has always worked for me. If I clear space on my external hard drive and de-fragment it, it seems to make the problem go away.
Posted on Sep 30, 2009
Whenever I try to connect dazzle it says.... failed to get video from device. It is coming from an xbox 360. and I know that xbox works with dazzle and pinnacle. I hooked it up all right.
donwload amcap
on amcap click
video capture filter
video image
tick the boxes
ext audio and usb audio
then go back to video capture filter
on video decoder
change the video to ntsc _433
then you will have audio and black n white picture then
change ntsc_433 to secam_B
than load pinnacle then capture/import
then you will have picture colour audio
Aug 01, 2010 | Pinnacle Video Transfer
Before buying a pinnacle video transfer I need to know if this appareil is vista compliant
Only requirements I see are video and audio input connections on our PC for the transfer/capture device. There are no actual drivers installed on Vista. If you are using Pinncale Studio software to work with the captured video, they do have versions advertised for Vista and Windows 7. If you have an older version, you may want to check the system requirements for that version. Upgrade versions appeared to be available.
Nov 11, 2009 | Pinnacle Video Transfer
No sinchronization between video and audio
Please check this link if this could help to you.
By the way where your video clips coming from? Importing or captured? If captured how did you connect your camcorder to your computer? How about the settings you used for capturing? In the capture mode>settings>capture format> did you choose mpeg1\2 or AVi? IF AVI kindly change it to MPEG. Let me know what did you make by replaying here.
Sep 27, 2009 | Pinnacle Studio Plus Version 11
I am not able to capture audio but video is fine. Trying both Windows Movie Maker and Instant DVD Recorder. Neither works. Also have checked input device and sources and recording volumes. Nothing is muted...
What kind of video cable you used? S-video or composite? if s-video did you also connect the red and white cable? If composite did you try to used another audio cable? Can you please try to visit and check your device manager and check if there is a yellow exclamation point.
Let me know it
Jul 28, 2009 | Pinnacle Dazzle DVD Recorder
I want to transfer casettes to a cd.
To transfer any audio or video casette to cd you need an audio casette player/vcp or vcr for playing back the video on the computer, a video capture card installed on the computer and the software to capture the video like Pinnacle which will save the audio/video file in mp3, mpeg format on the computer. The casette player or the vcr can be attached to the computer tower through the video capture card.
Jun 15, 2009 | Computers & Internet
We do recommend to capture in your Internal Hard driver first then transfer it later to your external hard drive. To avoid any eperience like video and audio is not sync or dropping frames.
Feb 07, 2009 | Pinnacle Dazzle DVD Recorder
Dazzle Platinum not capturing
I had the exact same problem with version 11.1 and was able to resolve it by going to the pinnacle websaight and uploading the latest drivers.
Sep 23, 2008 | Pinnacle Dazzle Video Creator Platinum...
I can not capture video to transfer to CD
Hi Crowey
Please check the driver of your camcorder if it is installed and
also try to check the kind of connection that you are using to connect the camcorder to your laptop.
Aug 06, 2008 | Pinnacle Dazzle Video Creator Platinum...
Audio/video synchronization problem
I have tried several versions of Pinnacle products over the years, and have had serious problems with ALL of them. Constant crashes, re-boots, glitches, dropped frames, etc. Sound lagging behind the picture is one of many problems, and can be avoided only be capturing short clips and editing them together. A real pain. i finally gave up on Pinnacle and bought Sony Vegas Movie Studio Platinum. It has a longer learing curve than Pinnacle, but in the long run it has more features and is very stable. Sony Vegas also works with Vista. Pinnacle 10 does NOT, depsite what Pinnacle and the salespeople tell you.
Mar 17, 2008 | Pinnacle Dazzle Video Creator Platinum...
S-video on pc
the audio gets plugged into the sound card (or on-board sound system) audio input jack.
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Pinnacle Video Transfer Logo
1,668 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
