Question about Kirby G5 Bagged Upright Vacuum
My Kirby bag is filthy as the internal bag broke. How can I take th bottom plastic piece off to wash the bag??? Please can anyone help!!! Thank You
  • Melanie Dargie
    Melanie Dargie Sep 11, 2008
    Have managed to resolve the problem. There is a tie around the bottom that you can remove and then it all comes apart and you can then wash the main bag. You can get a new tie from your local Kirby dealer.
    Do not wash the bag with any detergents just put it through a couple of rinse cycles through your washing machine and it comes out looking like new.
    You need to wait until it is totally dry before you put it back together again.
    Master:
  • 763 Answers
Madam try to shake the bag to remove the dirt if you cant remove the bag. or use a strong electric fan and let it blow the dirt. hope that helps
CHARCOIS
Posted on Sep 11, 2008
    President:
  • 1,263 Answers
The bottom piece is very durable and can be washed with it attached to the bag. do not dry it in the dryer let it hang and air dry.. please rate this
    Master:
  • 726 Answers
It should slide off or other wise it aint ment to come off as there throw away ones
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
Aug 25, 2014 | Kirby G4 Bagged Upright Vacuum
Kirby Ultimate G Diamond edition vacuum. We were told you can wash the outer bag. Is that true? How do you remove the bag to do this?
Twist the bag emptor left to remove it from the upright then your need a sharp narrow pointy object (like a metal dental pick cost $1 in most stores) push it under the plastic band around the rubber on the bottom of the cloth bag roll it across and take off the plastic tie once off pull the rubber bottom part of the bag emptor take out the inner plastic tube and zip the bag put in the washer by itself and wash with soap and softner and let hang dry you can also wash the inner plastic tube with hot water and fabuloso I recondition kirbys and do it all the time.
Jul 07, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I have a G4 and the plastic at bottom of bag is cracked
Hi There,
Well sort of. For the G4, the bottom boot is sold with the internal fill tube that inside of the outer bag, where the paper bag connects. These two parts are sold complete as an assembly already put together. You'll just need to take off the strap at the bottom of the boot that holds the outer bag onto the boot. This strap is sometimes difficult, and sometimes it's easier to just purchase a new strap and install it.
Here are direct links to the parts that you'll need on our website:
Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S
And here's the bag strap that you may just want to purchase so you can just cut the old one off:
Kirby Vacuum Bag Clamp. Kirby Part # 196599S
If you have any questions about how to change this part out, please feel free to open a new repair, or just use the comment field here on Fixya. If you found this repair helpful, please follow the Fixya way and leave feedback for the repair. This is really appreciated when someone answers your repair questions, and is what keeps repair professionals continue to post free answers rather then just the paid ones. Thanks again,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Kirby G4 Bagged Upright Vacuum
I have a Kirby G4. I have noticed the last few days when trying to vacuum that it is blowing more than it is sucking up. I put on a new bag to make sure it wasn't too full. I also put on the hose and...
take the mini emptor off(plastic piece on bottom of cloth bag) this is done by rotating it away from the body of the machine. There is most likely a clog there. Also take the brush head off and inspect fan for chips or cracks this will also reduce suction. let me know if you need further assistance
Apr 08, 2010 | Kirby G4 Bagged Upright Vacuum
Plastic tube inside fabric bag broke cleanly at the base.
It can be fixed by yourself, if you are some-what handy. The part is called snap fill tube and the part number is 1900399 your local vac repair shop should be aware of this number part sell for about $9.00 to $14.00 hope that helps.
Oct 31, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I detach the cloth bag from my Kirby G3 Vaccuum to wash it
I would clean the bag by blowing it out with compressed air (lightly). If you do wash it, do it by hand in room temp water and air dry. I'm not too sure how to remove the whole bag on that model. You should call your local vacuum dealer to inquire, and ask the same question you asked here on Fixya.
Jun 17, 2009 | Kirby Generation 3 Bagged Upright Vacuum
The bag latch on my Kirby Generation 3 broke. How do I get the old one off to replace it
at the bottom of the bag, there is a zip tie around the plastic part that turns & snaps on to the exhaust hole of the vac. also take a flat screwdriver & pull up the rubber under the zip tie...all the way around, like u would take a bike tire off a rim . then pull the bag holder/tube thru the bottom, then vise versa, when u put it back on.
May 07, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
