Question about Amana Washing Machines
Model lw6501w2 top load washer will fill with water and agitate but stays in that cycle and will go to the next only if you turn the cycle knob by hand otherwise it will stay running in the first cycle all day long if you do not manually turn the dial.
  • 943 Answers
THanks for the question the problem is with your timer Replace it Thanks for the question The appliance doc
Posted on Sep 11, 2008
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Whirlpool LXR9245EQ2 top loading washer tub won't fill
    try taking the knob off and see if the nut is tight on the timer,it might if came loose
    Jun 18, 2009 | Whirlpool Washing Machines
    Maytag washer won't fill or agitate; only spins on cycle
    sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
    Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
    Agitator not working 90 series model # 11026912691
    Hello aksward,
    Welcome to Fixya.
    Here are some suggestions for any Kenmore washers
    Let me know how it goes. I'm still thinking and searching my repair manuals!
    Huuum
    Please remember to leave a rating!
    KENMORE ELITE TOP LOAD
    Washer stops, won't fill, rinse or agitate
    • Check the following:
    Is the power cord plugged into a grounded 3 prong outlet?
    Is the indicator on the Cycle Control knob properly lined up
    with a cycle? Turn the Cycle Control knob to the right slightly
    and pull to start.
    Are the water inlet valve screens clogged?
    Are both the hot and cold water faucets turned on?
    Is the water inlet hose kinked?
    • Does the water level seem too low, or does the washer
    appear to not fill completely? The top of the agitator is
    much higher than the highest water level. This is normal and
    necessary for clothes to move freely.
    • Has a fuse blown or is the circuit breaker open? If problem
    continues, call an electrician.
    • Are you using an extension cord? Do not use an extension
    cord.
    • Is the washer in a normal pause in the cycle? The washer
    pauses for about 2 minutes during certain cycles. Allow the
    cycle to continue. Some cycles feature periods of agitation
    and soak.
    • Is the washer overloaded? Wash smaller loads.
    • Is the lid open? The lid must be closed during operation.
    Washer will not agitate or spin with the lid open.
    Oct 06, 2008 | Kenmore 22422 Top Load Washer
    Model LW6501W2
    Sounds like the outlet pump has siezed up due to having been stood for so long. You may need to take the pump apart, clean the shaft & reassemble. Or, you could try a spray with WD 40 on the pump. TURN POWER OFF FIRST
    Oct 26, 2007 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
    Washing Machines Logo
    110 people viewed this question
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
