Question about HP Office Equipment & Supplies
My printer says carriage jam I am unable to locate any jam
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
The carriage is the part that holds the ink. It is probably stuck in one place, either the top of one of the inks is open or something is in the way.
Posted on Sep 11, 2008
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
Carriage jam error
A paper jam
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website
Oct 25, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Desk jet 2360 cradle thrown left and right repeatedly then cradle jams.repeated errror codes of catridge,paper jam etc
Unable to find the encoder by the carriage assm, clean encoder & encoder reader sensor. (encoder is just like a film printed with lines on it, located behind the cartridge carrier)
Sep 12, 2011 | HP Deskjet D2360 InkJet Printer
I keep getting a carriage jam error message. There doesn't appear to be a jam, but I am unable to clear the message and print anything. Also the display screen reads original loaded. No idea what this...
Check the location of the ink carriage. If a piece of paper gets wadded up under this or something else is obstucting it you will see this error.
The original loaded message comes up when a sheet of paper is in the scanner tray.
Apr 01, 2011 | HP Officejet 7210 All-In-One InkJet...
Where is Jam 2 located
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Apr 26, 2010 | Brother HL 7050 Laser Printer
Brother MFC-5440CN, unable to print
Unable to print is usually a paper jam either in the far right or the far left of the carriage assembly, you need a flashlight to inspect for paper scraps caught at either end of the carriage travel area.
Sep 04, 2009 | Brother Multi-Function Center MFC-240C...
Reading Carriage Jam
Check all areas of the printer for any JAMS or anything that will stop it from printing and if this is unsuccessful then turn of you computer and take off the printer from the PC and reconnect it and wait bout 5 mins.
Then turn it on and the problem will have dsiappeared.
Dec 03, 2008 | HP Officejet 6310 All-In-One InkJet...
EPSON CX7300 locked carriage
you carriage is jam at the purge unit..u need to open all u printer cover..try to move the carriage slowly..couse it may can damage purge unit..
Oct 31, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Mar 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
102 people viewed this question
Ben Johnson
