Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
NO SOUND at all!
Everything was fine...then one day I turned on the TV and the sound was not there. Checked all the plugs and even unhooked the cable and dvd. Even with just the regular tv, the sound will not work. I also checked the switch on the back and made sure it was on internal mode. There has not been any other problems and the picture is still perfect. Everything else also works fine. The tv is only 3yrs old. No other warning noise or problems. I even hooked up a set of headphones to the outlet and ...nothing. I am not that savy with electronics so please explain in detail what I need to do or have done. Is this costly? Thanks for your help!!!!!!!
  • 4,889 Answers
It is odd for this model to have a sound problem. this is most likley a problem in the audio amp circuit in the tv. the problem is a repair cost will run 300-400. this is more than you should put into the tv. why dont you try running the aux audio out (rca jacks) on the back of the tv to a stereo and use the stereo for your sound?\let me know if you uneed more info here??
Posted on Sep 11, 2008
  • RCA Master
  • 8,617 Answers
The audio is controlled by the small signal board, which is very costly and hard to get, however I will post a link where you can get one for about half price. Its called the ITC small signal board and its actually a sale item at this site. Heres the link.
http://servicemanuals.vstore.ca/
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Toshiba 57H83 and no longer get any sound. Any
Most often No Sound with Toshiba 57H83 is:
1. TV has a Sound on-off switch on the input panel at the rear of the TV. Very hard to see, black on black. Used to turn off speakers if you use a separate or external sound system for speakers. Usually gets moved while connecting hd cables or dusting and vacuuming in cramped space at the rear of the TV.
2. Someone accidentally changed Sound settings with remote to CC (closed caption) or SAP. Turn off in sound menu and save preference.
3. Sound input plugs from external cable or sat box unhooked or wrong input.
Toshiba 57H83 no sound fault is not common. If you still have no sound, get local service.
Or troubleshoot yourself to determine if Tuner, IF, processing, sound demod, switching or sound output circuit is smoked. Then make an installation plan.
easyab
ConvergenceRepair.com
Feb 28, 2010 | Toshiba 57H83 57" Rear Projection HDTV
Jvc i art av 36f475: no sound
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Jul 28, 2009 | JVC AV-65WP55 65" Rear Projection...
I HAD TV ON. EVERYTHING WAS FINE. ALL OF A SUDDEN, IT BECAME SNOWY. LIKE THE CABLE WAS OUT. SO, I TRIED UNHOOKING DIGITAL CABLE BOX. AND HOOKING CABLE STRAIGHT TO THE TV. STILL, IT WOULD NOT GO ANY HIGHER...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the snowy problem; it does sound like aerial has disconnected. Try putting your finger over the aerial socket hole behind the TV while TV is on (using your self as an aerial). If snowy disappears then you have an aerial plug/wire disconnection problem.
Dec 06, 2008 | Televison & Video
My high definiton is working great and everything is fine except one major thing, which is that there is no sound at all. I would like to know how i might fix this problem.
Good Day, timerwer;
HD is fine but no audio! Not knowing that if you ever had sound, have surround system, hooked to an input or RF, I would suspect that you only have the Green, Blue, and Red cables hooked to your TV and the Audio cables ( red - white ).
If you do; unplug TV (reset, reboot) from A/C outlet for 3 to 5 minutes. If still no work try these suggestions:
1. Make sure the TV's internal speakers are turned 'ON'.
2. Make sure the "BOX" ( cable, sat, u-verse) volume is turned up all the way up.
Good Luck, big IRISH.
Aug 16, 2008 | Televison & Video
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
1999 RCA 62 inch tv
Does the picture come up..what is known as a raster(LIGHT) up. does it have sound.
Nov 29, 2007 | Televison & Video
HITACHI 51F59 51 " TV -- NO SOUND NO PICTURE
If it is only a few days over the warranty call immedieatly, if it is much over that then these newer Hitachis are in my opinion not worth repair, and I mean the newer under $1000 units the parts are near the origianl cost sometimes.
Jul 05, 2007 | Hitachi 51F59 51" HDTV Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
