Question about Mitsubishi VS-5043 50" Rear Projection Television
No Picture after it's been on a while. Audio OK.
Performs very well for a while (say 1-2hrs) then screen goes black (a thin red,green blue line shrinks to a pinpoint in about 1-2secs then only sound. Audio plays well. If I turn it off for 15-20 minutes it's fine. Seems more frequent the warmer the ambient room temp. Also I have a convergence problem that I can "fix" with a light tap (no kidding "light tap") to the side. The convergence problem goes away the longer the set has been on (say 20-30 minutes).
  • 1 more comment
  • Wayne McLurkin Apr 16, 2006
    "ic"= "integrated circuit"? Obviously I cant do this my self so any repair pros in the WashingtonDC area that may hel?
    I forgot to say "Thanks"!
  • Wayne McLurkin May 10, 2006
    The technician said that the "green tube (lamp?)" had leaked and affected the vertical (Scan?) integrated circuit and another one right below what looks like a copper tube running to the lamp and that the tube was no longer manufactured. I assume this is the coolant leak that I've seen in so many comments about Mitsubishi CRT projections because he said the leak was glycol used in antifreeze and that it is very corrosive to circuit boards. He said that he could fix/replace the circuits (including the convergence ic in the bottom right hand corner, but it would be just a matter of time (indeterminate but likely a short time) before something else would go out. He said that the blue was weak and showed me blue halos around bright white objects projected on the screen. Effectively he said he said it was unusual to have gotten 9.5 years out of that particular "chassis" and to continue enjoying it while I can, but basically plan to buy another TV.
    He was very patient, appeared knowledgeable and took time to give me what sounded like a logical diagnosis. I've spent $70 in other ways and gotten much less out of it.
    The funny thing is after he put it back together the thing looks better than it has in a long time and the convergencce issue hardly happens anymore.
    President:
  • 3,130 Answers
Ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Posted on Apr 16, 2006
  • Larry  Dillon
    Larry Dillon Apr 18, 2006
    Wayne, Contact at this # for a Factory service center 800-332-2119 or check online at CustomerCare@meus.mea.com good luck and let us know how you made out please.
  • Larry  Dillon
    Larry Dillon May 10, 2006
    You can buy after market rebuilt crt but like the tech said its over the normal life of the set. glad your happy with the pros.
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Insignia ns lcd32
Check the connecting cable to display paned and its T'Con board [LVDS cable] for any loose contact with its either end sockets. Reseat it once and check. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Jul 12, 2013 | Televison & Video
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
