Question about GE Refrigerators
I am looking for an installation guide for a new GE Profile, 25.5 cf, bottom freezer, refrigerator... model number PFSF6PKWBWW
    Novelist:
  • 171 Answers
Hi canmarboise,
I'm Harvey the Master Plumber.
You're looking for an installation guide for a new GE Profile, 25.5 cf, bottom freezer, refrigerator... model number PFSF6PKWBWW
There is only one place to go:
http://www.geappliances.com/service_and_support/literature/
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
How can i get the temperature to stay on it keeps shutting off it wont stay cold since it was left open 2 days ago
[PDF]General Electric Pfcs1nfzss Quick Specs - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../general-electric-pfcs1nfzss-q...
For answers to your Monogram,® GE Profile™ or. GE® appliance questions, visit our website at geappliances.com or call GE Answer Center® ... Counter-depth configuration - Counter-depth configuration makes it possible to have the look of ... Adjustable spillproof glass shelves - Raised edges keep small spills from ...
GE Refrigerator Not Running - Appliance Repair Guide
www.appliance-repair-it.com/GErefrigeratorrepair.html
In this GE refrigerator repair guide, I will walk you through the steps in ... They also added an electric damper that regulates the airflow between the fresh ... If you have aGE refrigerator that is not running the most common problem is ... Once the cover isoff, you should be able to see the main board. ... Temperature ControlMissing: pfcs1nfzss
GE Bottom Freezer Refridgerator fix. Evaporator Coil drain ...
? 2:25
https://www.youtube.com/watch?v=IiPRhr6nk54
Jan 01, 2016 | General Electric PFCS1NFZSS GE Profile...
GE French door profile freezer is not freezing
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Jul 03, 2017 | GE Profile Bottom-Freezer Refrigerator...
Freezer not cold and guide fan barely spinning
Do you see frost building on the back freezer wall? It could be a failed defrosting has plugged up the evaporator. You need to access the service panel and have a looksee. BOTTOM MOUNT SERVICE MANUAL
Apr 03, 2010 | GE Profile Stainless Bottom-Freezer...
Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Mar 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Clips missing from grill covering evaporator
you can put your model number in here, and look up the part and order from sears.
http://www.searspartsdirect.com/partsdirect/index.action
Jan 17, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
