Question about Nintendo GameCube Console
Power button failure
Ok here is the deal ..the game system shuts off during play..i have tried pressing it just right...the kids play it for 5-10 mins then it shuts down each time..how do i fix this...im hoping this is a simple problem to fix...respond asap to lonestar_angel_1975@yahoo.com
thank you for your time...
    President:
  • 894 Answers
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Posted on Aug 22, 2011
    D7160
    error 0xc05d1281 mean the ink system failure
    try blow reset Solutions
    Solution 1:
    • Press and hold the "*" key.
    • Press the "#" key and release both keys.
    • Display should say "Enter Special Key Combo"
    • Press and release in sequence the "1", "2" and "3" buttons.
    • Screen says "support" R0631M
    • Press and release the right arrow button until the display says "System Configuration Menu".
    • Press and release the "OK" button.
    • Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    • Display should say "Hardware failure status: Clear. Press OK to clear".
    • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
    • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    • Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    Solution 2:
    • Press * and # at the same time
    • Press 1, 2, 3 and "support R0632M" should display
    • Press > and "information menu" should display
    • Press > and "configuration menu" should display
    • Press OK and "hardware failure status" should display
    • Press OK "failure status: clear". Press OK to clear
    • Press CANCEL
    • Press CANCEL
    • Press CANCEL
    • Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
    • If the error came back, do the sequence again and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
    Solution 3 (thanks to a1224imac):
    • This same error started occurring on my printer and eventually it would constantly poweron and off.
    • Apparently some defective components were used in the construction of the logic board (see photo).
    • On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer).
    • I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents).
    • On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662.
    • If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
    Jul 22, 2014 | HP Photosmart D7160 InkJet Printer
    I am getting the message "Ink System has failed. Unable to print. Refer to printer documentation. Error:0xc18a0001." I have tried to shut it down and back on and it's still not working -...
    1. Get the unit into the "Support Menu" by following the steps below according with the product,
    A. - Press and hold the "left arrow" key.
    B. - Press the "Setup" key and release both keys.
    C. - Press and release the "OK" button
    2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
    3. Press and release the "OK" button.
    4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    5. Press and release the "OK" button.
    6. Display should say "Hardware failure status: Clear. Press OK to clear".
    7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
    12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    14. If the error is still there, or reoccurs replace the unit.
    VOTE ME IF YOU LIKE THIS SOLUTION
    Aug 12, 2011 | HP PhotoSmart C5150 All-In-One InkJet...
    Ink system failure
    An "Ink System Failure" error message displays on the printer during initialization or setup
    A. - Press and hold the "*" key.
    B. - Press the "#" key and release both keys.
    C. - Press and release in sequence the "1", "2" and "3" buttons.
    1. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
    2. Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    3. Press and release the "OK" button. Display should say "Hardware failure status: Clear. Press OK to clear".
    4. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    5. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    6. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    7. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    8. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
    9. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    10. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    VOTE ME IF U LIKE THIS SOLUTION
    Aug 12, 2011 | HP Photosmart C7280 Printer
    Ink system failure
    HP PHOTOSMART C7280 PRINTER
    Aug 12, 2011 | HP Office Equipment & Supplies
    Got ink system failure code # 0xc18a0501 on HP Photosmart C7280 a-i-o and no amoun of shutting down and restarting will help. What can I do?
    1. Press and hold the "*" key.
    2. Press the "#" key and release both keys.
    3. Display should say "Enter Special Key Combo"
    4. Press and release in sequence the "1", "2" and "3" buttons. The screen will say "support"
    5. Press and release the right arrow button until the display says "System Configuration Menu".
    6. Press and release the "OK" button.
    7. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    8. Press and release the "OK" button.
    9. Display should say "Hardware failure status: Clear. Press OK to clear".
    10. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    11. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
    1. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    2. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    3. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    If it did not print out a diagnostic page:
    1. Is the error message still being displayed on the printer?
    2. Print a self test page to check the functionality of the printer.
    3. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
    May 04, 2011 | Computers & Internet
    Ink system failure. States ink system has failed, unable mto print. Error 0xc18a0201
    Try the following tricks:
    Press and hold the “left arrow” key.
    Press the “Setup” key and release both keys.
    Display should say “Enter Special Key Combo”
    Press and release the “Ok” button Press and release the right arrow button until the display says “System Configuration Menu”.
    Press and release the “Ok” button.
    Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
    Display should say “Hardware failure status: Clear.
    Press Ok to clear”.
    Press and release the “Ok” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
    Press and release the “Cancel” button as many times as necessary, so that, either the “Welcome to
    Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.Please do not try to Print at this stage.
    Using the Power Button, turn the unit Off and unplug the power cable from back of the printer and wall outlet.
    Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
    Turn the unit on. The printer may display message “Use only the power button to shut down the printer” followed
    by “Press Ok to continue”. Press Ok. If the printer has already initialized, then go to the next step. If not, the printer will start the
    “One time ink initialization process”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    To verify printer functionality print a Self Test Page. If Self Test prints, then printer is ready for use.
    Good luck, Thanks for using FixYa.
    Jun 03, 2010 | HP Photosmart C6280 Printer
    Error 0xc18a0001
    The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold print photo's and the red eye removal buttons then press red eye removal then print photos then red eye removal again. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
    Jan 21, 2010 | HP Photosmart C6280 Printer
    HP ERROR CODE 0XC18A0401
    There is one fix for the 0x errors and it doesn't always work but this is the only option.
    Press and hold the "*" key. Press the "#" key and release both keys.
    Display should say "Support" and display the FW rev (something like R0631R)
    Mine reads R0631M
    Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
    Sep 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Power shutdown
    Did you update the firmware to 2.43? Many people have been getting bricked ps3s because of it. lets hope you still have warranty.
    Sep 20, 2008 | Sony Playstation 3 (PS3) Console
    Nintendo GameCube Console Logo
    133 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
