Question about HP PhotoSmart 7760 InkJet Printer
Keeps doing print alignment
Every time I turn my printer on before it will print it does an alignment. I have tried changing cartridges and it still does it. Any ideas?
  • 3 Answers
Re install the printer using the original disc. This should then reset the printer to its ariginal default. This problem should not happen, only if you have made changes since the original instalation. If this still happens, download an up todate driver.
Posted on Dec 04, 2008
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
Hi, Wonder can you help my printer keeps printing off test page everytime it is turned on. this is only happening since i changed the cartridge, never did this before. thanks
Your printer is printing alignment pages, because the cartridge alignment was not completed since you replaced them. Follow the below steps to complete alignment.
  1. Turn the printer OFF and then turn back ON.
  2. Wait until the alignment sheet prints out fully.
  3. Place the alignment test page over the scanner glass.
  4. Press start color scan button.
  5. The printer "power" light will start flashing, indication the alignment process.
  6. After the printer stops flashing, turn off and then ON the printer.It will not print any test pages further.
We need to run alignment test every-time while we replace ink cartridges.
Regards
Riztech
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
When i turn printer on it starts running as f printing then the message says align print cartridge
This is normal after cartridge change. It aligns itself by printing and reading. It has to complete this cycle or it keeps trying. If it asks permission, grant it.
Oct 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
kriegersugar@yahoo.com
Mar 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Keeps telling me to "Press Enter to Align Cartridges"
For some reason, you printer is lock on the alignment mode.
You can try removing power from the printer.
Remove both cartridges, unplug printer.
Wait 15 minutes and plug printer back into the electrical outlet.
Turn on printer.
Wait for printer to stop.
Reinstall cartridges.
Jan 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Aligning cartridges
first ckeck out your cartager are ok if your cartager are ok then when the align page print it will scan and once the align page is detected , align page printing will be stop.
Jul 06, 2008 | HP PSC 2210 All-In-One InkJet Printer
Print Cartridge Fails to align HP 7310
I was having the alignment problem with the black cartridge. After changing the cartridge, try turning the printer off then back on after 5 minutes. It worked for me.
Jun 10, 2008 | HP Officejet 7310 All-In-One Printer
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
HP1500 Alignment Test page keeps printing
I just had the same problem on a PSC1350 after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Dec 10, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
HP PhotoSmart 7760 InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
