Question about Ovens
Spark module clicks and gas will not stay lit, flame comes on but goes out
This is a broiler/ oven combo. The broiler is never a problem. The module in the oven gets a clicking sound and will ignite the gas, but then the flame goes out. It will not stay lit.The module has been replaced several times in the oven only, as I said the broiler has never been a problem. The old fashioned gas pilot lites were great....the electronic pilot ignition systems are a pain..........
  • sandmthomas Sep 13, 2008
    My problem is with an OVEN with an electronic ignition, not the cooktop burners....thanks anyway
  • Anonymous Dec 08, 2008
    I have the same problem with my verona oven, it lites but will not stay lit. Has anyone figured out how to solve this problem, or know an appliance repair company that services verona ovens?
    Sue
    Genius:
  • 1,239 Answers
Hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Posted on Sep 12, 2008
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Power cuts out 5 minutes after oven is lit
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 10, 2015 | Ovens
Why wont my oven stay lit
is the flame sensor positioned in the flame where it changes to bright blue near the flame tip
Aug 21, 2014 | American Range Ovens
Why won't my gas grill stay lit?
Oven clicks as if it is relighting almost constantly.
Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
GAS OVENS
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
May 16, 2014 | Whirlpool Ovens
Gas wall oven wont come up to temp.
ELECTRIC OVENS:
Apr 07, 2014 | Frigidaire FGB24S5A Gas Single Oven
My ovens wont stay alight i have a twin range gas oven and it just wont stay lit but if i hold the knob in it stays lit
I offer free advice bcuz God is so good!
GAS OVENS
ELECTRIC OVENS:
: I offer free advice bcuz God is so good!
Jul 31, 2011 | Belling Ovens
FGF374 - Broiler and Bake does not stay on
The flame sensor has to prove the flame to stay lit. When it fails, the valve closes.
Jul 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Mar 02, 2008 | Ovens
Ovens Logo
395 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
