Question about IBM ThinkPad A21m 2628 Notebook
Installing new Hard Drive Problems
My old hard drive failed and I ordered a new one. I have the Original Recovery CDROM but I don't have the Recovery Floppy that goes with it. I bought this used and I am trying to restore it to factory. Is there a download for the Floppy to go with the CD. The Users Manual says I have to have both.
A21m 2628-G1U, Windows 98, 128 Ram, 30Gb HD.
Please contact at E-Mail lupgaru@gmail.com.
  • Stephen Sep 11, 2008
    I will try that Robert, sounds logical. Wish me luck. I will write back with the results Thanks for your help!
    Stephen
    Brigadier General:
  • 5,158 Answers
I suspect you need both because the cd is not a bootable one. download a win 98 boot disk from www.bootdisks.com it will allow you to boot to dos.... then you change to the cd rom drive letter.. usually D: ... tho sometimes even X: and then type setup... that should start the restore.
Robert
Posted on Sep 11, 2008
Sandisk cruizer 8 gb detected as 64mb
Don't be panic. you can try some data recovery software. You can see
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Aug 14, 2012 | SanDisk Computers & Internet
My HP will not recognize sata hard drives
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error or
Restart your computer with the XP Setup disk in the CDROM drive.
If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead
Apr 28, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
My laptop crashed and we installed a new hard drive, as HP said, but we received a message that it did not recognize operating system. So we ordered recovery disks and put those in turned it on, still no...
ok, First you should understand the new hard drive is empty, it is not even formatted. At this point the most likely issue is the bios not recognizing the Hard Drive because the Bios is not set to automatically detect the hard drive. Enter the Bios and go to the hard Drive selection sub menu and have the computer automatically detect the hard drive size and type. Then go to the boot sequence menu and alter the boot order to CDROM, Floppy (If you have one), Hard Drive, Network. Reboot the computer and you should see the RAM test, hard Drive Identification and then the CDROM should start to boot. I can't be more specific about the steps because your post didn't include the model of the laptop. All of this assumes your CDROM is still in working order since HP laptops have a known issue with CDROM's going out for no reason. The hard way for dealing with this would be to get an encloser to put a hard drive in to make it portable and connect to another computer and do the partitioning and formatting of that new drive on the other computer and solve the problem that way.
Feb 16, 2011 | HP Computers & Internet
My toshiba HDD (Model-MK3265GSX) Serial Nunmbet 40LDF2NIS KK 8 EC . A has failed. It is not readable from outside. In order to recover the data, I need another good Toshiba HDD with a serial number close...
If the drive has failed then the only option to recover data is to send it to a data recovery service but these are not cheap.
Installing another drive with a close batch/serail number will not allow you to copy from a dead drive.
I would be connecting to a regular desktop computer and trying some of the free data recovery software available such as hirens boot cd.
ANY drive within the max and type supported could be used in your laptop.
Thses are common problems with laptops and in most cases I recover data (when the drive is not too damaged) as i described above.
I then install a new and often larger drive and build the system from the recovery CD's available from the laptop manufacturer.
Then old transfer any old data I recovered back to a folder on the new drive so that customers have access to anything that was saved.
The only sure way of getting everything back from a damaged drive is to send it off but that is only of use to you if your data is mission critical.
I use the cheap USB to IDE/SATA adaptors often available from good computer shops.
Feb 15, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Hard drive crashed. have new hard drive but can not install because cd rom will not work.. any suggestions
disable the cdrom on the BIOS/CMOS. then use a USB cdrom drive after installing your hard drive.
Jul 01, 2010 | HP Pavilion dv6000z Notebook
How do I read a hard drive taken from a WD Media
go into control panel click on administration tools storage there you can initialise and format
Jul 30, 2009 | Western Digital Media Center WDXF1600JB...
Cdrom drive and dvd drive won't read any cd
it is probably the hard drive failing as all of the items you have tried are on the hard drive
take it to a computer repair shop for a proper diagnosis
May 18, 2017 | ViewSonic Tablet PC V1100
Hard drive replacement w/system restore disc
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Mar 11, 2008 | Dell Dimension 8200 PC Desktop
IBM ThinkPad A21m 2628 Notebook Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
