Mitsubishi WD-62627 TV HD Problem: Has good picture at start up. 5 mins. in to operating picture changing colors slowly to more blue then green as time goes by with an opyic outline of people and objects.
    Novelist:
    Champion:
  • 203 Answers
Sounds like you are describing the Solorized Picture problem. This is a common problem on your model. Mitsubishi recommends removing and re-seating the DVI cable between the light engine and the chassis. If this doesn't fix it then you have to change the light engine. I have never seen a remove/reseat fix the problem myself but i have had a tech or 2 that i know fix it this way on occasion. Most of the time its a bad optical. Mitsubishi has extended the warranty for this problem on the 73" tv's but I do not think they are covering it on the 62" sets. If you are interested in going further on your own without a repairman let me know so i can assist.
Thank you
Tim
Posted on Sep 11, 2008
Model WD 62627 When I plug it in all that comes on is the timer green light at the bottom of the tv.
Replace the lamp of your tv or check it first if damage, feel free to send feed back good day and best regards.
Aug 22, 2011 | Mitsubishi Televison & Video
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 had power blink then green light blinks, unplugged over nite, now it comes on with loud static can't change volume, channel, no format, or menu
The chassi will have to be removed and sent to Mitsubishi to be rebuilt. Also PTS in Bloomington ,IN does this. The chassi is the box with all th input jacks and electronics on the left. This is very complicated but if you chose to do it let me know and i can give you some instructions. you may want to call mitsubishi or PTS and check on rebuild est first.
Mar 26, 2010 | Mitsubishi WD62627 62" HDTV
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
My tv is mitsubishi dlp wd 62627. has sound but no picture. may be the lamp??? or may be the video card???
I go more with the lamp, if it was the video card, your picture would be completely green or blue, but since what you have is the lack of image it's most probable your lamp is the one defective. You should also be aware that the lamps is powered by other components, if fixing the lamp does not solve your problem, you might have a faulty ballast, which is the board in charge of sending all the energy to the lamp so it can light up. http://www.discount-merchant.com/SearchResults.asp?Search=mitsubishi+lamps/?Click=48427
Nov 06, 2009 | JVC AV-48WP30 48" Rear Projection...
WD-62627 dark pic, contr. and bright. @ full..newer bulb.
You could try to INITIALIZE the tv by doing the following:
1) turn on TV
2) from the remote press MENU 2,4,7,0 then ENTER
3) TV will state that is INIATIALIZING
4) press the RESET BUTTON on front of TV.
5) hopefully it's fixed.
Sep 20, 2009 | Mitsubishi WD62627 62" HDTV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD-62627 Shutting Down
I was going to say that sounds like the power side to me mate the board power board check it out before you spend any money make sure it's unplugged before you do any thing and where a earth strap ok to stop you getter a shock ok
Jul 10, 2017 | Televison & Video
Open Questions:
Televison & Video Logo
275 people viewed this question
Top Televison & Video Experts
