Question about Dishwashers
F&P dishwaher 601 ver2 wont drain -
Thanks for the troubleshooting re the above post. Have finally got round to swapping controllers and still have the same problem.
1.How do you check motor to see if its working properly?
2.How do you take motor assembley/heat unit etc apart? The area where the rotor fits into is worn. Would this possibly cause the problem?
Appreciate your help.
  • fab9 Oct 25, 2008
    Thanks Neil V. This was the problem. Followed the instructions and is now running fine. Think the stator was partially buggered as well as it was not tight in its housing - plastic clips were worn!
    Anyway thanks again for the help. I always try to fix my own probs and usually succeed eventually with a little help!
    One question. What does the flap washer on the drain hose actually do? As the end where it fits is broken and its $50 for a new drain hose so i left it out and it still sems to run great. Will it do any damage. i will replace the drain hose if need be!
  • 27 Answers
Sorry for the delay!! If the area where the rotor fits is worn then this will definatley stop the water draining out. You will need to replace the stator assy and the rotor (if the faces are damaged).
HIS IS NOT AN EASY OPERATION..... The stator comes complete with the 2 o'rings. You will need to removed the wiring cover under the drawer, then remove the drain hose & fill hose from the dispenser, disconnect the wiring to the lower part of the controller. Squeeze the retaining clips at the rear of the drawer (underneath) you will then be able to remove the drawer completely from the cabinet. Flip the drawer over and carefully remove the wiring to the motor.lift up the retaining clip formthe locking ring, and turn the ring anti clockwise.The motor and heater plate will now be free to come away from the tub. I always lubricate the o'ring with washng up liquid which will allow the locking ring to slide easier. Good luck thisis not for the faint hearted!! Good Luck and let me know how you get on
Posted on Oct 25, 2008
  • neil_v Oct 25, 2008
    the flapper valve stops water re entering the drawer. You will probably get away with it so long as the drain hose exits the machine and is as high as possible, this will stop water flowing back into the machine. If you find this drawer always has water in the base you will need to change the drain hose. Cheers
I Have A Neptune Washer Model FAV6800AWW Have error code of LR Lock rotor? what is bad? control board ot motor or both?
Motor for the most part is bullet proof has a 10 yr warranty
I would start with front panel removal and see if you can rotate the Clutch Pulley CW the Wash/agitate direction and CCW the Spin direction. Make sure nothing is seized.
It could be an issue with the Control Board or the Motor Controller. I have working spares for all and that makes troubleshooting easier.
If you decide to troubleshoot further and try a Control Board swap (in the console) or a Motor Controller swap I would buy parts from a supplier that will allow you to return the part for refund with no questions asked.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
This is a sticky on a DIY forum at the 5th post down you can link to the FAV6800A/FAV9800A Service Manual. You can post in that forum in the Maytag washer forum for additional help. You will find a link to parts supplier.
I link you to a post on this forum where I was working with an owner who was troubleshooting issues and started throwing a LR error code. He ended up replacing both the Motor Control Board, my 1st suggestion and that did not resolve the issue. A Control Board swap in the Console resolved the issue. Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin ... I won't troubleshoot any further on this forum it's just difficult for me. Can't edit, search post and sometimes pics don't attach. There are better DIY forums out there for working on the FAV6800A/FAV9800A......just mu opinion.
Your machine more than likely is ready for an Tub Seal replacement.....Google this FAV6800A/FAV9800A Outer Tub bearing replacement Another forum I help owners with FAV6800A/FAV9800A machine issues........good luck.
Sep 06, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi my lc-30hv4u will not turn on is the fuse inside the black box marked 224 above were the power cord connects? thanks
The main AC fuse (3.15A 250V, soldered in the board) is the red round component on the power supply board AC inlet connector, see the picture here:
There are also other fuses on the board also.
You need to do indepth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 27, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Canon IR5570 - Problem: Black Copies The following parts have been swapped out from a working machine: DC Controller, HVT, laser assembly, reader unit, drum assembly, transport assembly, all the corona...
As I see that you have done near about all troubleshooting steps possible with the copier . Would request to check with Canon on the same if the copier is in warranty.
Canon Customer Support Center Hours: Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays Phone: 1-800-OK-CANON (toll free)
1-800-652-2666 TTD: 1-866-251-3752 (toll free) Email: For additional support options:
Jan 15, 2010 | Office Equipment & Supplies
Hi, on boot up from cold, computer hangs before post, only a long time of restarts finally kick it into action. please help!! alll volts are ok, have swapped mem around, checked bios.
Hi , Your bootup Relies alot on your RAM , swapping it around wont make a difference , Try running Memtest .
see if your Ram is ok , and take it from there , if it shows your RAM is faulty you might need to Replace it , and if it isnt Faulty , Try Taking 1 Part out at a Time and try booting For example , only boot with 1 Ram Card , Boot with MB GFX , and so on.
I Hope This helped
Dec 31, 2009 | Asrock K7VT4A-Pro Motherboard
Steady amber power led with 124 green led. No post.
Remove 1 of 2 ram sticks, and then if no post, swap round.
If you only have one replace this stick.
Sep 01, 2009 | Dell OptiPlex 760 MT Desktop Computer
Button swap
Usually this is regional languages problem.
go to, start, control panel, regional languages,
languages and keyboards
put english at the top, save it,
should be good.
Apr 22, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Bios Beep code
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
(I'm IT, I use these codes to trouble shoot hardware issues at my job. Enjoy) cold.gif
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning 1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard. 2 beeps Memory parity error. The parity circuit is not working properly. 3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory. 4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard. 5 beeps Processor failure. The system CPU has failed. 6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode. 7 beeps Virtual mode exception error. 8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card. 9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty. 10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS. 11 beeps Bad cache memory. An error in the level 2 cache memory. 1 long beep, 2 short Failure in the video system. 1 long beep, 3 short A failure has been detected in memory above 64K. 1 long beep, 8 short Display test failure. Continuous beeping A problem with the memory or video. BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes. 4-Beep Codes Beep Code Meaning 1-1-1-3 Faulty CPU/motherboard. Verify real mode. 1-1-2-1 Faulty CPU/motherboard. 1-1-2-3 Faulty motherboard or one of its components. 1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values. 1-1-3-2 Faulty motherboard or one of its components. 1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers. 1-1-3-2 1-1-3-3 1-1-3-4 Failure in the first 64K of memory. 1-1-4-1 Level 2 cache error. 1-1-4-3 I/O port error. 1-2-1-1 Power management error. 1-2-1-2 1-2-1-3 Faulty motherboard or one of its components. 1-2-2-1 Keyboard controller failure. 1-2-2-3 BIOS ROM error. 1-2-3-1 System timer error. 1-2-3-3 DMA error. 1-2-4-1 IRQ controller error. 1-3-1-1 DRAM refresh error. 1-3-1-3 A20 gate failure. 1-3-2-1 Faulty motherboard or one of its components. 1-3-3-1 Extended memory error. 1-3-3-3 1-3-4-1 1-3-4-3 Error in first 1MB of system memory. 1-4-1-3 1-4-2-4 CPU error. 1-4-3-1 2-1-4-1 BIOS ROM shadow error. 1-4-3-2 1-4-3-3 Level 2 cache error. 1-4-4-1 1-4-4-2 2-1-1-1 Faulty motherboard or one of its components. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 2-1-3-2 I/O port failure. 2-1-3-1 2-1-3-3 Video system failure. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 I/O port failure. 2-1-4-3 2-2-1-1 Video card failure. 2-2-1-3 2-2-2-1 2-2-2-3 Keyboard controller failure. 2-2-3-1 IRQ error. 2-2-4-1 Error in first 1MB of system memory. 2-3-1-1 2-3-3-3 Extended memory failure. 2-3-2-1 Faulty motherboard or one of its components. 2-3-2-3 2-3-3-1 Level 2 cache error. 2-3-4-1 2-3-4-3 Motherboard or video card failure. 2-3-4-1 2-3-4-3 2-4-1-1 Motherboard or video card failure. 2-4-1-3 Faulty motherboard or one of its components. 2-4-2-1 RTC error. 2-4-2-3 Keyboard controller error. 2-4-4-1 IRQ error. 3-1-1-1 3-1-1-3 3-1-2-1 3-1-2-3 I/O port error. 3-1-3-1 3-1-3-3 Faulty motherboard or one of its components. 3-1-4-1 3-2-1-1 3-2-1-2 Floppy drive or hard drive failure. 3-2-1-3 Faulty motherboard or one of its components. 3-2-2-1 Keyboard controller error. 3-2-2-3 3-2-3-1 3-2-4-1 Faulty motherboard or one of its components. 3-2-4-3 IRQ error. 3-3-1-1 RTC error. 3-3-1-3 Key lock error. 3-3-3-3 Faulty motherboard or one of its components. 3-3-3-3 3-3-4-1 3-3-4-3 3-4-1-1 3-4-1-3 3-4-2-1 3-4-2-3 3-4-3-1 3-4-4-1 3-4-4-4 Faulty motherboard or one of its components. 4-1-1-1 Floppy drive or hard drive failure. 4-2-1-1 4-2-1-3 4-2-2-1 IRQ failure. 4-2-2-3 4-2-3-1 4-2-3-3 4-2-4-1 Faulty motherboard or one of its components. 4-2-4-3 Keyboard controller error. 4-3-1-3 4-3-1-4 4-3-2-1 4-3-2-2 4-3-3-1 4-3-4-1 4-3-4-3 Faulty motherboard or one of its components. 4-3-3-2 4-3-3-4 IRQ failure. 4-3-3-3 4-3-4-2 Floppy drive or hard drive failure. 3-Beep Codes Beep Code Meaning 1-1-2 Faulty CPU/motherboard. 1-1-3 Faulty motherboard/CMOS read-write failure. 1-1-4 Faulty BIOS/BIOS ROM checksum error. 1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard. 1-2-2 1-2-3 Faulty motherboard/DMA failure. 1-3-1 Memory refresh failure. 1-3-2 1-3-3 1-3-4 Failure in the first 64K of memory. 1-4-1 Address line failure. 1-4-2 Parity RAM failure. 1-4-3 Timer failure. 1-4-4 NMI port failure. 2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory. 3-1-1 Master DMA failure. 3-1-2 Slave DMA failure. 3-1-3 3-1-4 Interrupt controller failure. 3-2-4 Keyboard controller failure. 3-3-1 3-3-2 CMOS error. 3-3-4 Video card failure. 3-4-1 Video card failure. 4-2-1 Timer failure. 4-2-2 CMOS shutdown failure. 4-2-3 Gate A20 failure. 4-2-4 Unexpected interrupt in protected mode. 4-3-1 RAM test failure. 4-3-3 Timer failure. 4-3-4 Time of day clock failure. 4-4-1 Serial port failure. 4-4-2 Parallel port failure. 4-4-3 Math coprocessor.
Oct 19, 2008 | Computers & Internet
Just bought a new 2GB memory card for my Fuji A340. Keep getting message 'Card Not Initialized'. Tried to format card to no avail. Gone through all troubleshooting solutions, tried to call Fuji support...
Sounds a bit like my problem with my Olympus 2gb XD card. Finally finished up half way round the world for an answear;I suggest you see if there are worldwide options for info. Post your problem and see what happens, I finally got my solution from Europe within 24hrs. Sorry I can`t help more just thought it might be worth a try.
Sep 23, 2008 | Cameras
Monitor works with one workstation but not another
OK; more basic troubleshooting is needed.
1] monitor doesn't work a] try on different cpu - check b] return with monitor from other cpu - ?
From the above I will try to spell out my steps.
1] notice monitor stops working
2] since I have another cpu close by - swap [it is important to also back swap {working monitor from other cpu]
analyze result.
I suspect that the video output somehow changed and the current display can't 'catch' what the video card is throwing.
does the display show the POST? is so, then you can start in safe mode and then set it to a low resolution.
Jul 21, 2008 | Computers & Internet
Canon DC100 - Finalizing Problems
thanks I got it plug-in the camcord to the wall outlet with DC adapter then you can start the finalizing thanks again
Dec 30, 2006 | Canon DC100 DVD Camcorder
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
