Question about Jenn-Air 35 in. JEC9536ADS Electric Cooktop
Fixing Jenn-Air Custom Control
Hi Todd,
Would you please give me the step by step instruction on how to replace the custom control?
Thank you
Sure, I meant to get a copy of the schematic last night so that I could send it to you with the changes. I'll get it tonight and send it to you along with the info I have now. The only thing that will be different is that you won't have independent controls of the dual element burner. For me that was fine cause my wife and I never use just the smaller burner but rather always both. The part #1009577 from repair clinic.com is an infinite switch which is already being used in the cook top for the largest burner or if not (cause I actually didn't look) for sure it is used in the JEC9536, just the wider model. This part is rated from 8.9 - 11.0 amps or 2,640 watts, when you hook the two burners together I believe it adds up to 3,000 watts so the infinite switch (the biggest I could locate) is slightly under sized. However, I felt most things especially electrical, are over engineered for safety any ways. When you remove the circuit board you will have to drill out the two slots where the two mounting screws will secure the new switch, or you can do what I did and stick a screw driver in the slots and stretch them slightly (very easy to do). You'll need to find two screws that fit the new switch for mounting ( not too long, if your not sure take one off one of the other infinite switches and match it up). I'll have to get back with you on the wiring, it is rather simple though, most of the connections are the same as the other infinite switches. The grainger.com part number 2FBT6 is just a snap action thermal switch that will replace the thermal sensor that went to the circuit board to light up the hot surface indicator. I tried to use the existing sensor but the hot surface indicator lamp stays lit, so I figured that the sensor was probably a 0-10volt or 4-20mAmp switch that the circuit board monitored and turned on the hot surface indicator accordingly. That is a simple hook up also, however, I have not installed that yet cause I did not find out about the thermal sensor not working for the hot surface indicator until after I put in the infinite switch. Tonight I will install it and let you know what wires go where along with a marked up schematic, maybe even photos if you would like.
Posted on Sep 11, 2008
  • todd in nove Sep 12, 2008
    Last night I installed the snap switch, however, it was the wrong one it opened on temp rise instead of close on rise so my hot surface indicator is on when cold and off when hot. The correct part number is 2E246 from grainger.com. I could not find a probe style switch so I removed the probe sensor and mounted the snap switch over the opening of where the probe was to allow hot air to activate it.
    It's not exactly what I wanted and the hot indicator lamp has a delay to come on and off however it serves the purpose of letting you know that the burner is still hot. You'll notice I bent the mounting flange on the snap switch, both ears straight out and one ear hooked back. The hook goes between the glass and the metal where the burner mounts, yes you need to remove the burner.
    The other ear I screwed to the burner. There is not much room so I
    marked and pre-drilled in the corner using care not to run into the
    element on the inside of the burner.
    I have modified the schematic showing my connections:
    I have put the part number over the guts of the switch because I did not want to confuse anyone. When you are looking at the switch installed the above diagram is how the wires will be connected, very similar to the other switches already in the stove.
    The yellow and tan wires I joined at the switch by cutting off one of the spade connectors, stripping the wire and soldering it to the top of the other spade connector.
    I also cut the probe wire connector off and soldered one end to the top of the spade connector attached L! (black). I stripped the other probe wire(also black) and the red wire coming off the hot surface indicator lamp and soldered them together then I wrapped them with some fiberglass tape (white cloth) that I removed from else where on the stove.
    Note: Unless you have heat resistant wire and tape you need to recycle the wire and tape within the stove. Standard wire and tape could melt and or catch fire.
    After that I cut off the probe trying to leave the wires as long as possible. I crimped on good fitting spade connectors, (female, uninsulated), then connected them to the snap switch.
    That should be it.
    Note: Make sure to reconnect the cooling fan and once you have the stove back together on the bench, remove the fan cover and check that no wires are blocking the fan blades. (I have made both of these mistakes once.)
    It seems like a lot of work but it really is not and it is rather easy.
Hi Todd-
I used your solution and it works great. I did need to use a normally "open snap" action switch to get the hot indicator lamp to turn on and off correctly. I used Grainger's 2E248 switch, which closes at 140F and opens at 120F. This was a pretty simple and effective solution.
Posted on Apr 12, 2010
Hello Todd in nove,
I would like to thank you very much for this post and the time you
took to put it together. I just made the mods to my cooktop as
directed and it works perfectley !!!!!!! I recommend this repair.
now it's the hotest burner on the cooktop. $34. total cost v.
$188. and no more electronic parts in cooktop.
Posted on Mar 14, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
On my JEC9536ADS the front right know has been bent too far sideways when the cooktop was being cleaned and now it is loose and feels broken. I guess this is the one that controls the infinite burner. Do you think just the knob is broken or is it the whole switch that has to be replaced?
Posted on Aug 14, 2010
The left front burner turns on but is on high all the time and will not go down to low heat
Hi you are going to have to replace the burner control , this is a easy fix and the thermostat assebley isent that expensive if you give me the info on the unit i will find a part for you Frank
Jul 09, 2011 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Clickin noise and no heat on JED 8230
clicking nosie is due to problem in ur power board.
please look at the relays
Jun 18, 2008 | Jenn-Air JED8230 Electric Cooktop
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
MODEL JEC9530 CUSTOM CONTROL ELEMENT TURNS OFF BETWEEN THE 4 AND 6 SETTING. WHICH PART (NUMBER) IS REQUIRED FOR REPAIR?
i would start with the infinite switch itself
you can find this part at appliance parts pro one word dot come
type in your model number
your looking for part number
AP400965 they are currently in stock
unfortunatley it is expensive around 150.00
tell them your a servicer
working for myyellowdog
it may get you a discount
have a great day
Oct 08, 2009 | Jenn-Air JEC9530ADS Electric Cooktop
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Nov 30, 2008 | Cooktops
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
Jenn-Air 35 in. JEC9536ADS Electric Cooktop Logo
1,365 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
