I just purchased a used projector. I was told it was tested prior to shipment. However, I cannot get a clear image. It has pink and green blur or misallignment. Not really sure how to describe as it is not really a shadow. I cannot locate a use manual and did not come with one. I'm hoping this is something simple and obvious and not an issue caused by shipment or truly wrong with the projector and not disclosed.
It is not a focus issue. I have tried options within the menu and frequency, contrast etc. make little to no difference. I have it hooked up to a laptop.
SOURCE: EZPRO 610H...has a red shadow
this is ghosting, caused by interferance. cheaper cables tend not to have metal sheathing and those ferrite RF suppression thingees on the ends, which prevents this problem.
also, avoid running your signal cables next to power cables. If your cables are long (say more than 10m) this may also cause problems.
SOURCE: optoma ezpro 610h projector displays
over heating and/or bad fan. if the fan stops or slows down, replace it. try www.projectordoctor.com
ditto...
