Question about Canon MV500i Mini DV Digital Camcorder
Remove cassette tape (message)
Every thing was working fine ,then the camera started to damage the tapes leading to the above message it now does not work at all as soon as you put a new tape in you get the message to remove it although it doesnt appear to damage tape now,if it was humidty it should have dried out as it happened in october when we were in greece
    President:
  • 3,130 Answers
No I doubt if it was humidity that was causeing the problem as you would have had an error of "DEW" Sounds lke you have a tapepath problem or a jammed mechanism and that would tell you to eject the tape as it wouldnt load to full position. I would advise on a repair like this you let a pro do the repair unless you know all about these small mechanism Call 1 800 828-4040 good Luck
Posted on Apr 15, 2006
GL2 is eating or damaging tapes.
Thgis is a fault in the tape transport mechanism.
It should go for service To open this and try a DIY may well result in it never going back togethyer again properly.
Thanks for using FIXYA
Sep 23, 2009 | Canon GL2 Mini DV Digital Camcorder
It sounds like a mechanical problem (not a moisture problem). There's no quick and easy way to say what's wrong with it without actually tearing it apart and inspecting it. I would advise trying a repair shop other than the one you have already tried. If you can, find a canon authorized service center.
Nov 06, 2007 | Canon MV500i Mini DV Digital Camcorder
JVC GR-DVL109E Digital Video Camera
Hi, Assuming you have a JVC MiniDV Camcorder, the E04 error message means that the rotation of the video head has stalled or is too fast. When the little motor that pulls the videotape through the camera detects that the tape is not moving at the right speed, you get the SAFEGUARD MODE error. The principle here is that the camcorder detects a problem and shuts down in order to avoid doing additional damage to the unit. This is a legitimate way of protecting itself. The problem is that there are many reasons why the unit might not be able to move the tape, and obviously the question is: Why it is happening to my unit in particular? If your unit is still under warranty, then by all means run to JVC and have it diagnosed and repaired for free as soon as possible. Once your warranty runs out, if you start getting these errors again, it can cost over $150 just to have JVC look at it. Then possibly several hundred more to repair the unit. A few Quick Fixes to try: In most cases you should clean your camcorder's heads by running a cleaning cassette through. A little trick some have tried to eliminate this error message is to keep the cassette door open and then pull out the battery. Doesn't work? keep trying this routine. Some people actually report getting the error message to clear. Eject the cassette and just when it is about to eject, push it back in... and the error is gone. In Depth Solutions: Solution #1: Cold Reset The reason it tells you to REMOVE AND REATTACH BATTERY is not that the battery is bad, but that removing all sources of energy (battery and power cord) causes a COLD RESET. When you use the unit's on/off switch, parts of the camera are still receiving power and so you do not get the benefits of a COLD RESET. Just like your car; turning the ignition off will still power the clock and radio. You have to completely remove all power. If you are lucky, the camera will reset itself and start working again. Solution #2: Awareness of Humidity It seems older units would issue the same SAFEGUARD MODE error message for more than one problem. For example, older units do not tell you that they are shutting down for an hour because they detected high condensation, or moisture. So you play with the camera, remove the battery, reattach it, remove the tape, reinsert it, stand on your head, pray to your god, go to the bathroom, and voila! The camera is working again. It was nothing you did, just that the humidity went down enough for the unit to start working again. So consider high humidity as a possible source of the problem. If it is a rainy day, or you are near the sea, you might never get it to work that day in that location. Solution #3: Head Cleaning If you have never used a head-cleaning tape on your camcorder, you might give that a try. Mine has come back to life a few times by doing just that. Just don't do it too many times in a row because you can permanently damage the head. Read the instructions. So we have covered a few reasons why these errors come and go as if by magic. They are intermittent and recurring. The camera will appear to work at times, and the next minute it shuts down. Solution #4 : Fake Solutions Another reason why the problems come and go is that, as several technicians have reported, the problem can be a loose connector inside. That is why some people report that tapping the camera gently or rocking it side to side has brought it back to life. Some have gone as far as putting cardboard between the tape door and the tape mechanism in order to exert pressure and keep the camera working. I can only warn you that these kinds of "repairs" are temporary and likely to damage the unit further. Solution #5: Compressed Air On some models, there is no shield covering the many delicate electronic and moving parts in the tape mechanism when you open it to replace the tape. A piece of dirt, grain of sand, or other debris can get caught in the tiny gears and stop movement or throw them off alignment. You can explore this possibility by getting a can of compressed air at any computer shop and blowing it into the inside of the camera. Follow the instructions, keeping the air nozzle however many inches away from the target as they say. Practice on some other object first, because if you tilt the can or hold it too close to the target you can freeze the target and do more damage than good. This applies to fingers too! Solution #6: Tape Age, Brand, and Type Have you tried using a brand new tape? Or only your really old ones? Try a new tape. Now for the controversial issue of what brand of tape to use. Controversial because JVC's own Stacy Sample, Service Coordinator for JVC in Houston, TX says that "TDK and Maxell tapes tend to be two brands that are very problematic in our digital line wherein Panasonic, JVC and Fuji seem fine. We just find that TDK has the most problems, Maxell is a close second and Sony is 50% of the time. A different point of view I ran into is. Yes, there is an issue, but it has nothing to do with the brand, but with the tape type. There are MP and ME tapes. These two types use different particles, and different lubrication. The two lubricating materials form some sort of goo when mixed together, if you use both types of tape in the same unit. So as long as you don't mix tapes of different types, they will work just fine in your camcorder. Some refer to these types as "dry" and "wet", but I don't know which is which. In any case, it is not known (to me) how accurate this point of view of not mixing tape types is. Solution #7: Do not store tape in unit Because of the delicate nature of the miniDV mechanism, do not store the unit with a tape inside. The theory is that a loaded tape will put pressure on parts of the mechanism and increase the chance that parts will stick together, making the tape harder to be pulled by the motor, causing the SAFEGUARD error. regards sreejith
Jul 18, 2007 | JVC GR-DVL109 Mini DV Digital Camcorder
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the motor.so remoce the mechanisum and fix with a new one.
Oct 20, 2008 | JVC COMPACT VHS-C CAMCORDER
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Sep 16, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Playback Problems
THE FOLLOWING SOLUTION FROM LABBER (CREDIT TO HIM)
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS LABBER
Nov 13, 2007 | Panasonic NV-DS29B Mini DV Digital...
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Tape Won't Load
try this quick fix. check and see if the video head is bound. I have seen alot of these stick. put your figure on the top edge of the head only and see if is free spinning on not. sometimes you can more it one way or the other and free it up. this problem could also just require a tape path cleaning. anything sticky on the tape path or head will cause this.
May 03, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Canon MV500i Mini DV Digital Camcorder Logo
202 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
