Question about KitchenAid KEMC377K Convection / Microwave Oven
KitchenAid Built-in Microwave Oven
Recently i had a problem with my microwave. When i pressed start on it, the microwave just had DOOR on the screen and it didn't work. So then I checked out the door and there was nothing wrong with it. So i pressed it again and the same thing kept happening.
Can someone please help me with this problem
  • KitchenAid Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
If the door switch is not properly activated when the door is closed, the controller thinks the door is not shut and it will not start.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 16, 2008
Kitchenaid KBMS1454BSS Starts and stops, then restarts and stops, etc, at different intervals.
PDF]BUILT-IN MICROWAVE OVEN Use & Care Guide - KitchenAid
www.kitchenaid.com/.../KBMS1454BBL/Use%20and%20Car...
KitchenAidWe have provided many important safety messages in this manual and on your appliance. Always read .... Touch CANCEL/OFF and reset the clock if needed.Missing: kbms
KitchenAid kbms 1 Kitchen Ranges Questions & Answers ...
www.fixya.com > Forum > Tags > kbms 1 > Kitchen Ranges
KitchenAid kitchen ranges kbms 1 related questions and answers. ... Control panelreset answer Steve, Thanks for providing your answer to my question about ...
Nov 07, 2015 | Microwave Ovens
Built in microwave light bulb for kitchenaid
Need model number. If this is one of those built-in wall ovens with microwave on top (with the door that drops down), it is definately NOT something the average customer can do himself. It's a 45-minute job for an experienced technician!
Oct 18, 2014 | KitchenAid Microwave Ovens
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
Microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid Microwave Ovens
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
F2 Message Code
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 03, 2009 | KitchenAid KHMS155L Microwave Oven
No Touch Screen Display
Try pressing "Clock" and then "Start"
Mar 16, 2009 | KitchenAid KHHS179L Convection/Microwave...
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid KEMC377K Convection / Microwave Oven Logo
105 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
