Afficio 450 sc 322
Wat is sc 322 how can i fix it.. can any1 help me...
  • 2,794 Answers
1st laser synchronization error.  This should be looked at by a Ricoh technician to see what needs to be replaced.
Posted on Sep 11, 2008
Also it can be the front door switch,
Also if you try to clean mirrors inside laser unit. Clen them with air.
Posted on May 13, 2015
AFFICIO 450. WHILE STARTING A MACHINE GETTING A GEAR NOISE COMING AND GETTING A ERROR SC 329. WAT COULD BE A PROBLEM KINDLY ASSIST ME .
sc 329 is the laser unit problem. the noise is not gear, it is laser noise. you have to replace the laser unit mate. thats the only solution.
Dec 08, 2010 | Ricoh Aficio 450 Copier
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
Changing developer in afficio 450
Preform SP 2-801 then 2-805.That will do it!
Jan 21, 2009 | Office Equipment & Supplies
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Jan 14, 2009 | Office Equipment & Supplies
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
247 people viewed this question
k24674
