Question about Canon EOS 630 35mm SLR Camera
630 EOS draining battery with unit off
The 630 which I have will discharge the battery in 6 to 10 days with the unit turned off. What could be causing the drain on the battery and is there a fix? The unit functions normally with a new battery. The pictures are fine and the film rewinds normally. Dray
WHO fixes Canon EOS 630 battery drain problem at a reasonable price?
Posted on Dec 06, 2008
    President:
  • 3,130 Answers
Best way to handle this would be to get a manual and take apart the unit and monitor how much current the units drawing as when off Im thinking it shouldnt draw anything. Or call here and ask about a repair cost. Good luck Main support number1 800 828-4040
Posted on Apr 15, 2006
Why does my car battery drain overnight
After checking that there is nothing left on which could do this (you would notice) the likely causes are
- battery self discharging due to end-of-life
- fault in the alternator unit permitting discharge to earth
An auto electrician can see which very quickly
Dec 01, 2014 | Cars & Trucks
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
Battery won't stay charged
1. the car drain's the battery even when it is not started or the key isn't in ignicion, the car has a electrical problem, you left a light, the starter could drain it, the alternator as well, or a bad radio is draining the battery even with no key in the ignicion,
2 it's a bad battery (discharges it self by beeing counicated inside).
solucion 1. to see if the car is drainin the battery would be by disconecting a battery termina and see if discharges again, if not, then the car drain's the battery.
solucion 2. if the battery discharges even when if it's disconected from the car, then change the battery.
warning, the first cause coul'd induce to a self discharging battery. even if you changed the battery, do a litle monitoring to be sure it's not the car that is turning the battery bad. how? if you install a new battery, leave the car for a few days (i mean do not start the car) and see if the battery discharges, if so, then you have to search what is draining the battery (that could be a very costly work, time and money and complicated). or put a ''battery disconector'' so the car cannot discharge the battery.
Apr 05, 2014 | 1994 BMW 3 Series
I have a 2007 GMC Envoy. I've had to jumpstart the SUV for the last 2 days. Could it be the battery?
Either the battery, the battery cables/connections, the alternator or alternator cables/connections (in the extreme a drain could cause battery discharge). Have battery tested. Look for signs of corrosion around cables. If vehicle won't start after sitting but will restart when turned off, suspect battery. If won't restart after driving, suspect alternator.
Jul 09, 2009 | GMC Envoy Cars & Trucks
Battery Drain CaNON eOS 630
This is a quick repair for under $60 at most independent repair shops.
Crystal Camera Repair
Asheville, NC
Dec 06, 2008 | Canon EOS 630 35mm SLR Camera
Canon EOS 630 Will not power up
Well.. the EOS 630 is a really old camera.. they don't last forever.
First thing I would recommend... test the new battery with a volt meter or battery tester, just to make sure it didn't die on the shelf. Or try another one, just to be sure.
Next, check the battery contacts, preferably under a magnifier. You could have corrosion, or a bent contact, that might be preventing contact with the battery.
Assuming none of those work, you have a more complex problem. It certainly might be fixable, but you'd want a good repair tech to take a look at it. However, that's probably a bad idea.. they charge by the hour for actual repairs. You can find a working EOS 630 on eBay these days for under $30, sometimes with accessories. I wouldn't spend much money trying to fix this, but a few checks around the battery area are a good idea.
Dec 02, 2007 | Canon EOS 630 35mm SLR Camera
Recurring dead batteries
Get it serviced to find out if it is repairable or only insert battery to use then remove when not in use
May 10, 2017 | Canon EOS Rebel T2 35mm SLR Camera
Canon EOS 630 35mm SLR Camera Logo
196 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Norman Worley
Are you a Canon Photography Expert? Answer questions, earn points and help others
