Question about Canon PowerShot S3 IS Digital Camera
"Memory Card Error,""Card Locked"
I just won this camera on eBay. It was listed as a working camera, but after I purchased it I find out (in the finer detail) that the camera has a message in the window that says; "memory card error" and "card locked." Have I been (forgive my term) screwed?
I haven't actually got the camera yet; should be a couple of days. I thought I should do as much research as I could.
Do you have any suggestions, or should I dispute this sale?
I appreciate any help,
HIGHLY INEXPERIENCED
  • stanlickd Sep 11, 2008
    Thanks very much for your help. As I said, it should be a couple of days before I get this camera. When I do, I will let you know how this solution worked. It sounds good to me; and once again, thanks a lot for your help.
    Stanlick
  • stanlickd Sep 16, 2008
    I got the camera, and did what was recommended. I very much appreciate your help; unfortunately, as beautiful as this camera is, I believe it's TOAST! It will cost more to fix than I paid for it; about $160.00 to repair. I paid $130.00. I have contacted the dude, and explained the problem. I haven't heard back yet, but, hopefully I won't have to file a dispute.
    THANKS AGAIN,
    stanlick,
  • 56 Answers
Don't Panic there should be no trouble with this sale, The Canon Powershot takes SD memory cards which stands for Secure Digital, Secure in the fact that the memory cards have a tiny switch on the side of them that can be locked so that there cannot be anythong written or deleted from the card.
This is probably what has happened to this camera, nothing to do with the actual camera but with the SD memory Card.  To fix it just switch the tiny switch on the side of the Sd memory card to the unlock position and everything should work fine!!
Cheers
Emmanuel
P.S Can you post the link to the ebay auction as this would be very helpful.
Posted on Sep 11, 2008
  • Emmanuel Higgins
    Emmanuel Higgins Sep 11, 2008
    Now worries! Let me know if it works.
  • Emmanuel Higgins
    Emmanuel Higgins Sep 16, 2008
    Sorry to hear that :(
    so the camera won't read any memory card?
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
I won a Canon PowerPoint S3 IS at an eBay auction; it was in the working camera listings. It turned out that in the finer detail, the owner said that everything worked except for the "Memory Card...
yes go ahead and dispute it as if it does not read the card there is a fault in the camera and its to much to get repaired mine was 160 dollars when i could have brought a new one add the link to ebay ill have a look and show you how to dispute also on ebay main page it says contact us
Sep 15, 2008 | Cameras
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
My camera says protected card. What does that mean, it won't let me snap a shot or nothing
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Sep 14, 2011 | Polaroid i835 Digital Camera
When iput my sd card in my camera it says card locked even though the card isnt locked what can i try
There are several possible causes for "memory card locked", "memory card error", or "no memory card". If moving the tiny slide switch on the card didn't help, see other troubleshooting steps for this problem listed here.
Sep 03, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
I just bought new 4gb sandisk. I have a kodak easyshare cx6330 camera. It won't format. Any suggestions
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 31, 2011 | Kodak EasyShare M1093 IS Digital Camera
My camera says it is a memory card error, the card is good and I even tried a new one. Is there a fix?
Your camera model can only use 2GB or less standard SD cards. Fortunately, 2GB standard SD cards are relatively inexpensive these days, and may be purchased on Amazon or eBay. There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Mar 09, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
