Question about ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...
No audio i already install the k888111 driver package and realtek hd driver.. but still i have no sound.. i try to uninstall realtek but this massage keep showing (unable to uninstall)
  • 5 more comments
  • Anonymous Sep 13, 2008
    NO AUDIO
  • nxyz215 Sep 14, 2008
    sir, i try to disable the hd setting from my bios,,
    but when i try to uninstall my realtek from my add and remove program, it show the massage (realtek removal failure).but when i check the folder realtek from c:/ it was gone. what should i do about these.
    and 1 thing, when go to my device manager clicking on my sound, video and game controller.
    there are no yellow balloon on my icon..
    only these 5 device show
    -Audio Codecs
    -Legacy Audio Driver
    -Legacy Video capture Driver
    -Media Controller device
    -Video Codecs
    and there is no yellow marked on these devices..
    i really need your help..
  • nxyz215 Sep 18, 2008
    sir i cleaned my registry with regcure and install the realtek ac'97 audio driver,.
    But still i have no audio.
    when i go on my device manager and click sound, video and game controller
    the realtek audio does not appear and also in my system devices the bus driver for my audio does not appear...
    and in my bios only my front panel speakers can be set to ac'97..
    is that ok if the if the main panel is hd and my front is ac'97?
  • nxyz215 Sep 19, 2008
    sir thank you very much for your time and advice..
    i really appriciate it..
    thankyou again.
    i will return my board from where i got it...
  • Anonymous Mar 06, 2009
    i have no audio. Bruce
  • kirbynsik Mar 06, 2009
    i have no audio.
  • Anonymous Mar 29, 2009
    no audio on this board.
I have installed this P4M890 VIA chipset's audio with HighDefinition Audio for ADI 198x. And really can work.
Posted on Mar 15, 2009
...try disabling lan in bios.
Posted on Feb 11, 2009
    President:
  • 2,351 Answers
You may not have downloads the correct driver software. The Asus P5VD2-VM SE uses the, Realtek Audio Driver V5.10.0.5490 for Windows & HD driver, Realtek High Definition Audio System Software V5.10.0.5366 for Windows. You can download both from Asus by clicking on this link;
http://support.asus.com/download/download.aspx?modelname=P5VD2-VM%20SE&SLanguage=en-us
Please read all of page 1-34 in your P5VD2-VM SE manual to help you setup your audio. You'll need to make a bios change per instruction. If the current software does not uninstall. Enter the bios & disable the setting for HD as shown on page 2-24. Save & exit the bios. The system will auto restart. Try again to uninstall the software, it should uninstall. Create a folder on your desktop & name it HD audio. Download the HD audio software into the HD folder. Do the same for the standard Realtek AC'97 software by creating another folder within the HD folder & naming it, Realtek AC'97. Store V5.10.0.5490 into the Realtek AC'97 software there.
Both files will need to be uncompressed. Enter your bios again & Enable either the [AC'97] or the [HD] setting. Save & exit the bios. Go back into windows device manager. Open the + sign to the left of Sound, audio and game controller. (It will open if it's not already opened).
Rather trying to reinstall by using the sound software's setup.exe file we will do a more direct method of installation.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find you’re desktop folder named HD & open it. Left click once on the folder named (Depending which you are going to install), Realtek or HD, so it is high-lighted. Than click OK.
Windows will find the correct driver software & install it automatically. Once completed. Close all opened windows & restart you’re system. Test your audio. If you intend to use a mic, you will need to set this up through the Sounds audio devices within the control panel.
If you run into any issue just post your question here.
Good luck nxyz215!
Mike
Posted on Sep 12, 2008
  • 1 more comment
  • Mike Peluso
    Mike Peluso Sep 14, 2008
    Hi nxyz215, from what you typed the device manager does not show a valid sound driver installed. So download the two drivers from Asus as suggested in my post above & uncompress the download as instructed. I want you to also download a free registry cleaner. Click on this link. http://www.pctuneuptips.com/recommends/c...
    Once downloaded, run it. Let it clean your registry. When it finishes restart your system.
    Open the HD folder on your desktop than open the AC97 folder. Run the setup.exe for the AC97.
    This should over write the sound driver you installed (k888111).
    When finished shut down your system. Than boot it back up & enter your bios. Go to page 2-24 in your manual. Set High definition audio to, [Auto] than set configuration options to [AC97]. Save the bios & exit. After the system loads try your speakers.
    There's always more than one way to fix an issue. Trouble is finding the correct path.
    Mike
  • Mike Peluso
    Mike Peluso Sep 19, 2008
    Hi nxyz215, according to the manual it is not ok. (Did you hear audio)?
    If after the AC'97 drivers were installed & still there was no AC'97 in device manager you will not have audio. (It’s a must for Realtek or AC'97 to be listed in the device manager). The two pictures shown at the top of page 1-34 is showing you two different configurations using the same 10 pin layout. If the pin lay out is connected as; AAFP, to the front panel audio you should be able to select HD in the bios. If you use configuration; Legacy AC'97-compliant layout, than the bios will only allow you to set it to AC'97. Since the bios is only allowing you to set it to AC'97 than the front audio connector must be already configured for AC'97. (Again nothing will matter if there is no AC'97 in windows device manager).
    There is one other setting you can try. (This is not in your manual). Looking at the picture configuration for AC'97. Pin one is located, bottom row & first pin left side. Pin 2 is across from pin 1. Pin three is to the right of pin 1. This continues to 10. (Though there is not a pin for number 8 you still count it). Grab your self two, 2-pin connectors or jumpers (Just like ones used on a hard disk drive). Place a jumper over pins 5&6 & over pins 9&10. Set the bios setting (Top of page 2-24), High Definition Audio To; [Disable]. Plug your speaker system into the light green audio port at the back of the PC. If the bios setting to [Disable] fails to allow you sound from your speakers change this to [Auto]. Keep the configuration options to [AC97]. (You will no longer have front audio by doing this).
    If none of this has given you sound than the onboard audio chip is bad. (This is common with Asus boards & though today’s boards are better I'm still finding this issue from time to time). Here is a bit of good news. Your board was made sometime in 2007. Asus warrants their boards for three years. So your board is still in warranty. Though a defective sound chip can not be repaired, Asus will end up exchanging it with one that does. (Same model). Please call Asus tech M-F 8:00AM to 5:00PM EST at: 1-812-282-2787. (You'll need to write down the information found on the pink LPT port. There is a white sticker). The Asus tech asks for that information in order to help you. The tech may give you another suggestion that may fix this issue. These people know their boards. The way this works is you ship the board back to Asus bare. 7 to 14 working days, Asus will ship a working board back to you. (Don't forget to ask for a new bios. (This usually is free but you go to ask). If you are not located in the US you can still do the above. Click on this link; http://support.asus.com/contact/contact....
    Good luck nxyz215!
    Mike
  • Mike Peluso
    nxyz215, rating of yellow is not very nice. Though I can not fix your motherboard it is not reason enough to rate yellow. You can plainly see I spent alot of time putting together every possible configuration. I know Asus boards & would not suggest you return the board if it was not warranted. Since you are going to follow my suggestion & return the board it would be considered a fix & a blue rating. If you found this to be helpful only a green rating. Yellow is thank's for trying. No matter what I say you still have to do the work. If it leads you to a fix its a blue.
    Mike
No sound, drivers can't be found
right click on the red X icon select playback devices there will be a red x on the speakers right click configure them
hope this helps
Jun 27, 2012 | Gateway Computers & Internet
Uaa hd bus driver loaded but didnt let me install realtek driver
First of all go to *********** board or pc website. select the model and automatically you will get the uaa hd audio driver.
and one more thing before you install the fresh HD audio driver please uninstall the previous one and are you running XP SP3....
Feb 17, 2012 | Computers & Internet
I need sound software
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers
cnetdownload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price fromthe category drop down list select drivers then from the price drop down list select free or which ever applies to your need or you could try some of these
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition.
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
hope this helps
Update your embedded sound from Realtek to the latest AC
Jun 18, 2011 | Intel Celeron D 2.4GHZ 533FSB Barebones...
Realtek audio not install
If you are having problems with you sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps
Jun 18, 2011 | Computers & Internet
I have uninstall my realtek hd manager i have no sounds now what should i do now
realtek hd manager is bundled with audio driver, if you uninstall it , this mean you uninstall audio driver too, just install again audio driver and you got your sound again
i hope this helpfull, if you think this helpfull please rate very helpfull or helpfull
thanks for using fixya
Jan 20, 2011 | Computers & Internet
Install realtek hd audio driver failure error code oxe0000227
1) open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio"
2)uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.)
3) install realtek driver the realtek driver includes the UAA driver too.
Jun 07, 2009 | MSI 945GM2 H-F (816909015911) Motherboard
No sound after installing update to realtek hd audio driver
There is no sound after installing realtek audio driver. What to do next?
Jan 18, 2009 | Adapters.com Genica Realtek A-8100 PCI...
ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...  Logo
1,495 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
