To can to computer : Take the document and lay it on the glass. line up the corners. On the top of the printer press scan from the menu and the printer should start scanning to computer.
Hi........
click here for solution.........
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Place your document facedown on your device scanner, then you can use a software provided by your driver of scanner and just click first a preview so that you can view your document or picture to be scan, then click scan. Wait until it finish then put it on a location where you want to save.
What computer do you have? On Mac I go to the System Prefs, Hardware, Printer & Fax. A panel will let you pick Scan to get started. Be sure to stretch the corners of the scanned area on the preview screen to include the whole document you want scanned. If you have a PC, there should be a scan function in the Office software, perhaps under Admin, or other general area. Gluck, Jim
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
