Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
ERD36 Oven over heats
In all cooking modes (bake, conv, pure conv, broil) the main bottom element stays on constantly. The over heats past the set point ( say 375) well above 500. The display does not show the high temperature just the set point. I shutoff the power to see if that reset the controller but no luck. If it was a welded relay I would expect the burner to stay heated even when I set it to off.
Is this a controller board problem?
  • wilfw Sep 28, 2008
    Once I found the circuit diagram I was able to determine that the problem was the main burner relay contact being welded shut. This relay is not part of the controller. It is on a separate board mounted just above the oven cavity and a real witch to replace. After getting the board out I desoldered the faulty relay and soldered in a replacement. Cost $15.
  • 116 Answers
If the oven stays off when turned off then it is definitely a controller board problem. - that would mean the element is coming on and there is no control - changed the controller
Regards
Posted on Sep 23, 2008
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
heatman101
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
196 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
