Question about RCA R52WH73 Projection Television
HDTV R52WH74 PROJECTION POWER STAYING ON ISSUE
I left on vacation and unpluged all electronics as i allways do when I leave for more than 2 days. When I returned, pluged all back in, I sat down to watch tv. The tv power up fine but after watching it for about 5 mins the picture went from good picture to blinking on and off 3 times the power led never shut off until the last blink then shut off. It took about 2 mins before I could get it to turn back on it lasted about 30 sec and just shut off and every time I got it on .checked the remote to be sure it wasn't it, waited about 30 mins and the same thing happend in order. Im thinking some kind of power supply or maby a solder connection opening can u help? Im a Ind elect so i should be able to fix this my self Thx Shanoconn
  • RCA Master
  • 8,617 Answers
Thats usually related to the flyback and or cp150 capacitor. You can get the replacement flyback number 259296 and the replacement CP150 at the following link with free instructions
http://servicemanuals.vstore.ca/
Posted on Sep 11, 2008
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
There is a faint buzzing sound coming from the 50HDX82 TV. If I turn up the volume of the TV, then one does not hear it, but if you do the '1/2' mute, you hear it a lot, if you mute it completely, you do...
I know this will sound stupid but try it, unplug just power cord, leave it unplugged for 2 hours then plug it back in. This will reset it to factory setting and if this issue was caused by a power issue it will fix it.
Nov 09, 2010 | Toshiba 50HDX82 50" Rear Projection...
My RCA - R52WH74 television will not turn on.
You need to replace the flyback and the H.O.T. transistor. the 270125 flyback with H.O.T. repair kit from www.tvrepairworld.com should fix that issue. The kit also contains the CD with detailed instructions
Jan 06, 2010 | RCA R52WM24 52" HDTV Projection Television
My rca tv model no r52wh74 goes off after a few minutes and wont come on until about 10 minutes then goes back off again?
What the problem is here is you have a bad power supply or you need to do a hard reboot. On this tv to reboot you need to unplug it from the wall and leave it unplugged for about four hours if not you need a power supply
Nov 20, 2009 | RCA R52WH73 Projection Television
I too cannot get the TV to turn on but my model is a R52WH74
the chasis number of your tv is eithor itc222 or itc221 the deflection board causes most of the problems part number 258762 part discontinued but you can contact eithor pts electronics or tristate module to see if they can fix yours
Sep 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA r52wh74 tv powers on then powers right off
one solution to maybe solve the problem of it not staying powered would be to take the panel off the back and use a blow dryer in the lower left hand corner and heat it up. It worked to get our tv turned on.
Jun 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca hdtv model r52wh74 turns off after 25mins and wont turn back on. I have to leave it unplugged for a while for it to turn back on. I also had the convergence problem, switched the fuse, and it fixed it....
Hi I am Vortash sorry to say you have an engineers nightmare fault an intermittent or slow to show .. this requires bench testing to catch the fault as it happens .. it will probably need an oscilloscope to monitor the psu and an MMM and a multimeter .. not the type of stuff most people have around the house unless you are an electronics engineer sorry to say but this is one for the man with the van .... Regards Vortash
May 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
RCA R52WH73 Projection Television Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
