I want to do a system recovery on my e-machine but I don't know the procedure. Can you tell me how?
    Brigadier General:
  • 5,158 Answers
Boot up with the disc in the cd rom drive.... if it doesn't boot to cd i'll explain that next.... follow the instructions on screen.... if it reboots during setup do not hit any key to start the boot from cd ... be aware there is a difference between system restore and system recovery... the last one usually formats your hard drive so you lose all the data on it.
Robert
Posted on Sep 11, 2008
Forgotten password and backup disk not working so how can i factory reset
That depends. It may or may not be possible. Most PCs today come with no disc media. The user is responsible for making their own recovery disks using an application that the manufacturer provides on the machine. Even then, most manufacturers know that the average user doesn't take the time to read the User's Guide and often will not make the recovery disk(s). There is almost always an extra partition on the hard drive that has the factory-installed image as a backup should you corrupt the original. The procedure(s) to access this and perform the recovery vary by manufacturer and even model, so without that information, we cannot tell you if you have that capability and if so how to access it. If the media you have was supplied with the machine, there may well not be any other means of recovery short of purchasing a new Operating System disk and reinstalling manually.
Sep 02, 2016 | Computers & Internet
Tip
How to restore factory default
Toshiba laptops from mid-2007 onwards don't have a recovery disc supplied with the laptop. Instead, Toshiba has added a hidden partition on the hard drive which contains the same files as a recovery CD/DVD.
WARNING: All data and added programs will be deleted with this procedure. This procedure puts your laptop back to it's initial "out-of-box" factory settings. Make sure you save any critical data onto another device (CD, Flashdrive, External Harddisk, etc) before performing this procedure.
To restore your laptop to its factory settings using the hidden partition:
  1. Hold down the power button for ten seconds to switch off your machin. Please note that holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
  2. Press and hold the zero key and at the same time, tap the power button once to power on your notebook
  3. When the machine starts beeping, release the zero key
  4. When prompted by the warning screen, select Yes to continue with the system recovery 5) Select Recovery of Factory Default Software and click Next
  5. Select Recover to out-of-box state and click Next again
  6. Click Next to Start the recovery
on Apr 11, 2014 | Toshiba Satellite Computers & Internet
My computer will not recognize apple products
Do a system recovery to a date the system worked ok. The system recovery is in programs then click Accessories then under the tool menu.
Apr 13, 2017 | Audio Players & Recorders
Samba 1845 won't boot how can I make it do so?
From what I can tell it would be HDD related. Have you test the HDD, is good? Do you have a Recovery disk of your OS? The machine has some miles on it ,right? I would start trying to load the disks (CD) that came with the machine, (I don't know your OS), If you don't have them, you can search for a windows repair disk online.
Nov 18, 2012 | Computers & Internet
How do i reboot my laptop
Restore to factory settings
Restoring your Sony VAIO computer to its original factory settings is a great way to remove old programs and files that are buried within your computer that you no longer need, or to get rid of a virus that you just can't seem to shake.
This process will allow you to start anew with your computer, and can potentially save you from simply throwing the computer away because you don't think it can handle the workload anymore and spending money on a new machine.
Unplug any cables connected to your Sony VAIO machine with the exception of the power cord and monitor.
Click "Start" in the lower left corner of your screen.
Click "Control Panel."
Click "Performance and Maintenance."
Scroll down to the bottom of the Performance and Maintenance screen and click "VAIO" recovery wizard. The VAIO Recovery Wizard dialogue box will appear.
Click "Next."
Select "Proceed with System Recovery" and click "Next."
Select "C Drive Recovery" and click "Next."
Click "Next" to confirm that you want to proceed with the C Drive Recovery.
Click "Finish" to restart your Sony VAIO machine and initiate the recovery procedure.
Upon restarting your computer, the Sony VAIO Recovery Wizard will prepare your hard drive for recovery and then restart your computer again.
The necessary files will be copied to your computer and your hard drive will be recovered.
Click "Finish" when a screen appears telling you that your recovery process is complete.
Your computer will restart.
Click "Next" when you arrive at the Windows setup screen.
Follow the on-screen instructions to setup your version of Windows.
When you have finished setting up Windows, click "Finish."
Upon restart, the Sony VAIO Recovery Wizard will install necessary files on your computer.
Your computer will restart automatically when these files are installed and your Sony VAIO will be restored to its original factory settings.
Hope this helps
Oct 14, 2012 | Sony VIAO Laptops (Laptop NOT Included)...
How do i restore the emachine
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse.
Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Source(s):
hope this helps
Sep 16, 2012 | E-Machines eMachines Desktop PC
Reset my desktop backc to the original settings
Source(s):
hope this helps
Aug 01, 2012 | E-Machines eMachines Desktop PC
I ran the operating system cd and i don't know what i did. Now everytime I try to start my laptop it tells me "a disk read error press crtl+alt+delt
Put your recovery disc in again and boot from the cd then do a full system installation of your operating system.
Jul 07, 2011 | Computers & Internet
Please after changing the battery of my VOLVO v40 1999 wagon car the radio requested code can you help me
This is a anti-theft device built into your radio designed to foil robbers. When the radio looses power, the radio locks up. This makes the radio worthless on the black market. The thieves know this and don't steal it as a result. Your owners manual tells you to clear the code if there will be a power loss (changing the battery). There may not be a recovery procedure.
In the GM (1995) version of this system, there is no recovery (if there were, what would be the point of the system?). I don't know the specifics of the Volvo system. You may want to talk to your dealer before you replace your radio. I am sure you will have to prove ownership of the vehicle.
Thanks for your question @ FixYa.com this morning.
Jun 21, 2011 | 2000 Volvo V40
How do i reboot toshiba without the cd
Hello, please follow the step,
Toshiba System Restore Vista Step 1 - "Initiating the HDD recovery procedure"
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.
Choose the entry "Repair your Computer" and press "Enter":
2. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and click on "Next".
If unsure, just click on "Next".
3. the following screen a window with your username appears.
Type your windows password as you would log on to your account and press "OK":
4. The next screen offers several options to repair or diagnose your computer system.
To start the recovery, click on "Toshiba HDD Recovery":
Step 2 - Performing the HDD recovery
1. After passing the previous screen, you will be asked if a backup of your important data is already made.
You can continue with the recovery process by clicking on "Next"
2. Confirm the following screen also by clicking on "Next"
3. You will be asked again if you want to recover your machine (and delete all files on your harddrive).
There are no additional options regarding the harddrive, which can be set. Click on "Yes" to start the recovery.
4. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
5. By pressing the "Restart" button to restart the machine, the recovery procedure is almost finished
Step 3 - Finishing the recovery process
1. After the successful completion of the recovery process and the restart of your machine, the following screen should appear.
2. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly installed system and to finish the installation of the operating system
FOR WIN 7 Toshiba System Restore Windows 7
How to recover a Toshiba with the HDD recovery procedure
- Operating System: Windows 7 - 32 Bit, Windows 7 - 64 Bit, Windows Vista 32 Bit, Windows Vista 64
Bit
The following guide describes how to recover a Toshiba with a preinstalled Windows windows 7 from HDD through the
"HDD recovery procedure".
Please note:
First of all, make sure you already back up your important data!
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.Choose the
1. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and
click on "Next".
1. In the following screen a window with your username appears.
1. The next screen offers several options to repair or diagnose your computer system.To start the recovery, click on
1. After passing the previous screen, you will be asked if a backup of your important data is already made.You can
1. Confirm the following screen also by clicking on "Next"
1. You will be asked again if you want to recover your machine (and delete all files on your harddrive).There are no
1. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
appear.
1. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly
Hope this helps,
Hope this helps,
Jan 25, 2011 | Toshiba Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
