Question about IBM ThinkPad T23 2647 Notebook
CRC1 0175 Error
At start up immediatly after POST error appears. CRC1 0175 Error and eeprom checksum error. all fucntions are disabled except the power button.
  • 5 more comments
  • niaz Nov 16, 2007
    i am having ibm thinkpad t22 model whenever i am starting up my laptop i am getting error mesaage 0175 bad crc.i have changed my cmos battery but still getting the same problem if anyone know the solution of this problem pls inform me
  • Anonymous Mar 31, 2008
    i on Power of labtop then Start this error ( Error 0175 CRC1 Stop task )
  • Anonymous Jun 17, 2008
    How can i fix the error crc1 0175?????
  • Anonymous Jun 21, 2008
    I get this message every time I try to boot my computer.
    IBM Thinkpad T23 Bad CRC CRC1 Error 1075 Stop POST Task
  • mushir3 Jul 11, 2008
  • nelad Aug 09, 2008
    0175:bad CRC1, stop post task..
  • Anonymous Sep 02, 2008
    i have to tryed to change hard drive
    President:
  • 3,130 Answers
Have you tryed to as soon as the power is switched on go to safe mode to see if you can find a driver or hardware issue??. At start up keep pressing f8 all the time till it comes up. after that gointo and check all the drivers you got and see if theres a conflict or a reasourses fault. as windows will tell you if everything is working right as you check everything sepaerate. If it wont go that far then you have a fateal error and may need to redo the hard drive by formatting and reinstalling the os. It sounds like maybe a F.A.T virus??good Luck
Posted on Apr 15, 2006
System shows crc error. means you have problem in cd rom or cd drive
Posted on Feb 02, 2008
Think it has something to do with your BIOS-EEPROM, which, in the worst case, needs to be flashed over serial bus!
Posted on Sep 06, 2007
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
F1E2 error code
Here is the part to order.
Nov 04, 2012 | Whirlpool Duet GHW9150P Front Load Washer
A 1xx POST error code indicates a problem with the ??
It indicates a problem with the system boards. For more info, start here.
Oct 30, 2012 | HP Computers & Internet
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Code F6 Oven will not work with any button, I get
Hi janishanson,
The F6 fault code description is an EEPROM checksum error. The EEPROM checksum error occurs when the values differ. In this case, you need to replace the mainboard or control board, also called as ERC.
Hope it helps.
Thank you for using FixYa.
Jan 15, 2011 | Dacor Preference RSD30 Gas Kitchen Range
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
1.
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven has error E1 F1 will not work
F1 - E1
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
CRC Problem
Chances are since the system CRC1'd it has a very old BIOS revision. From version 1.10 on, the CRC issue has been fixed. So, get the latest BIOS from IBM, T21 BIOS: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/spsdkz34.exe and flash the BIOS. Reboot the system and verify the updated BIOS. Now power down the system, desolder the known good EEPROM and resolder the CRC1 EEPROM. Boot the machine and hit ESC when the splash screen comes up and watch the post screen. The new BIOS should have recalculated the EEPROM checksum and written the changes to it. You'll know if it worked because the CRC1 error will be gone.
Jan 03, 2009 | IBM (09N5424) Motherboard
CRC1 0175 Error
This error is typical of a problem with the system board.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4K2MCU
I've only seen this error appear on IBM thinkpads. Your EEPROM with the following steps.
You can try this to test the EEPROM
1.unplug AC,battery, HDD and and your cd/dvd rom drive.
2.press power button,last more than 10 seconds
3.plug battery and AC power
4.power on
5.when see the IBM logo,press F1 button immediately.
If the same error pops up, try it a few more times. If the error keeps displaying then it is the motherboard
Feb 23, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T23 2647 Notebook Logo
2,193 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
