Toshiba Satellite C655-S5125 Logo
Anonymous Posted on Sep 02, 2011
After running windows7 ultimate on laptop, some keys on the keyboard are giving different commmands. help
Anonymous
Level 3:
Guru:
  • Master 846 Answers
  • Posted on Feb 06, 2012
Anonymous
Master
Level 3:
Guru:
Answers
846
Questions
0
Helped
217737
Points
2769
Update your Laptop's Drivers Using the below Softwarehttp://www.devicedoctor.com/device-doctor-download.php
And update your windows to service pack 1http://windows.microsoft.com/installwindows7sp1
Hope it helps...Have a good day
1qaz keys not working
If you plug in a different keyboard, what happens?
If it works with a different keyboard then your original keyboard is broken and you should replace it.
Acer aspire 9410-4317 running windows7 Ultimate,where's all the acer management stuff
This link may help you:
http://acer.custhelp.com/app/answers/detail/a_id/2631
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Help im changing my tx2150ee from windows vista to windows 7... can anyone help me how to do it? im new at this
You have 2 ways to upgrade from vista to windows7: 1- instaling windows7 from vista (this need to insert setup dvd of windows7 while windows vista it's running and choose to upgrade to windows, but this you can do only if vista and win7 are both 32 bit or 64 bit, you can't upgrade from 32bit to 64 bit), but i don't recomand this way because all programs installed on vista will remain on hard drive as a folder and you lose some space on hard drive. 2- clean install of your copy of windows 7. For this before you start install widows save all your data from partition C to another partition. After that insert your windows7 setup dvd and restart your computer. When your laptop is starting you will see on screen "press any key to boot from cd", just hit any key to do this. if you can't see this message go to bios and change boot option to boot from cd/dvd. For this restart your laptop and hit F2 or DEL key while restarting depending of what chipset your laptop have (try both) and go to boot and there you have instruction of what key to use to change option at the botom of the screen. Now i give you step by step instructions to install windows7: -after boot you will see a window "Install windows", here you can choose language, time, and keyboard type then click next -in next window click on install now -in next window you have licence agreement, click i accept and then next -from next window choose custom install -then choose from the right side "drive option (advanced)" -choose disk0 partition2 (usually is second option, just watch partition dimension, if you have more of one partition) -then choose format -click ok in next window -then click next -now your install is started -after restart write user name and computer name and clik next -type a password if you need one or leave space empty if not and click next -write your windows7 serial and click next -choose first option for windows updates -choose your time -if your windows installed any network driver in next window choose were you use your laptop -thit's it now you have o fresh copy of windows7 Good luck!
2answers
I need to upgrade my windows7 professional from ultimate
If you are trying to change from Windows 7 Ultimate to Windows 7 Professional this is actually downgrading. I would suggest staying with Ultimate unless it is causing performance issues because in order to go back to Professional you will have to wire the entire computer clean.
Windows 7 Ultimate has all the same benefits as Professional plus more. Here is a chart comparing the different editions: http://www.microsoft.com/windows/windows-7/compare/default.aspx
I hope this helps.
Need to change Apire 5732z from Spanish laguage to English, kindly assist
To install a different language - Multilingual User Interface (MUI) - you need to have Windows 7 Ultimate.
Anytime Upgrade to Windows 7 Ultimate
Type Anytime Upgrade in the Search programs and files box in the Start menu and click on the Windows Anytime Upgrade icon. From there, you can buy an Anytime Upgrade to Windows 7 Ultimate. Then your can enter your Anytime Upgrade product key and perform a simple upgrade to Windows 7 Ultimate so you can install a different language.
If you are in Australia, Belgium, Canada, France, Germany, Italy, Japan, the Netherlands, Spain, Sweden, Switzerland, the UK, and the US you can use Anytime Upgrade. If not you will need to buy Windows 7 Ultimate, or buy Windows 7 in the language you need.
http://windows.microsoft.com/en-us/windows7/products/windows-anytime-upgrade
Install Language Pack in Windows 7 Ultimate
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
1helpful
Shift key - how to type @ sign in hp mini 311
Not sure this that model, but till you get a better answer may I suggest you use on screen keyboard so you can at least use an @ symbol.
to get that: Start Menu, All programmes, Accessories, ease of access, on-screen keyboard
That is me guiding you via the Windows7 menu system, your Windows might be different so might be under "system tools" for you
Should help you for now.
2answers
Problem with my operating system windows7 ultimate
You need to reinstall any other operating system.
If you have any imp. data then boot into safe mode, back up your data then reinstall windows
Can not get my key board to respond when coputer boots up,
Do you get video at least?
Do you get keyboard during POST? (Try turning the system off, turn it on and keep hitting F8 until you get to a windows boot selection screen)
Does Windows boot all the way up but you just cannot interact with the laptop? Try plugging in an external mouse/keyboard/speakers, or remove it from the docking station if it is attached to one.
If you get keyboard/mouse before windows (able to move up and down the boot selection screen), then Windows may just need to be reinstalled for some strange reason.
If you still aren't getting anything, the motherboard may need to be replaced.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
