Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Cannot connect to my wireless network
Hi, It's been three months and I cannot connect to my wireless network. The change happened when I went to my mom's house and tried to get onto her wireless network. Whatever I did, it didn't work there. I came home and tried to get onto my wireless network and nothing. I tried repairing the device and it says it can't finish because it can't connect to the network, contact my network administrator. I know the wireless is working from going to the configure address. I now have to plug my laptop into my wirless device with an ethernet cable in LAN1.  I have a Philipps ADSL multiservice modem/wireless router. My wireless card is whatever came in a Sony VAIO 2 years ago. HDAUDIO Soft V92 with IntelPro network adapters. There is security on my network, but that was never a problem before. Right now the network is mixed (11b +11g) and its on channel 10. So when i got my xbox 360 i connected perfect on a wireless network with the wireless network adaptor. But then my 360 broke down so i sent it to the microsoft repair shop and today they sent it back. So i plugged it in and connected my wireless adaptor to it and when i did a connection test it vertified that my w/a was plugged in but it would pass the connection test? so i called microsoft and did everything they told me but it still wouldnt work for somereason?? can u help me with this problem?
  • 1 more comment
  • Anonymous Sep 27, 2008
    My wireless computer worked just fine before we moved to another county. Now , my wireless cannot connect to the internet regardless of what I do.
    My desktop works just fine. I thought a router would fix this problem.
    What do I do now?
  • handaza9 Oct 14, 2008
    i have a wireless network connection i can't log on to the internet with my laptop as the computer indicates a connection and good signal
  • Anonymous Jan 31, 2009
    IE flashes and then quits ..... I have no internet connection .....Laptop is very slow and no working well. To say ther least. I assume there's a virus but can't connect to update my AVAST.
    Sergeant:
  • 213 Answers
I think you have more than one connection in your settings of the same name
follow this step
1right click on network icon( connection in network)
2.device manager
3.select all wireless connection then
4. delete all the connection
close the window
now it will show the new connection
click pop up and click connect
enter yor pass key
NOTE: it will ask only if your securty is enable
Posted on Oct 22, 2008
    Problem Solver:
  • 13 Answers
Is their a wifi switch on your laptop, if there is try changing its position to on if it is on off, then do a search for wireless networks, if this does not help unplug your router, and plug it back in, if none work then replace your router or check for drivers on your laptop as you may have accidentally deleted the wifi card driver, try driver robot and it will tell you all the uninstalled drivers, if anything is to do with wireless communications or intel wireless or anything similar search the make and model of your laptop and type 'wireless driver' (without the quotes) into google and do a bit of searching, install one and if that does not work, i cannot help any further.
Posted on Sep 24, 2009
I have hp wireless computer it was working well for 1 year but now it dose not work it dose not see the connection for the wireless and their
is red light near the place were you open and close the wireless . what can i do i need help
Posted on Aug 15, 2009
Everything works well on my wireless linksys e2000 router my itouch, my computer except my samsung wireless lan adapter wis09abgn cant seem to connect to the internet on my Tv i plugged it in the usb slot...
IT looks like it might not be accepting the type of security on the router..try changing the security typa it might work.
(P.S. YOu might need to re-connect all the wireless computers to the new network once you change the security.)
Hope this helped.
Feb 13, 2011 | Computers & Internet
WG111 v2 cuts in and out of connection. says scanning for network address. has been working for three months. i have tried everything i know to fix it. thanks chris
Check the wireless access point you are using for problems. If someone bought the same brand near you then they may be using the same channel which would cause the problem you are describing. In that case change the WAP to use a different channel.
Good Luck!
Oct 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
PC Can See Wireless Networks, Cannot Connect
The services of your windows XP may not started yet. Follow these steps:
Start > Run > type services.msc and click OK
on the services windows , look for Wireless Zero Configuration and then right click and select start.
try to reconnect on the wireless
Please let me know if there is a progress....
Sep 03, 2009 | Computers & Internet
Whilst online my connection went off using my belkin 54g, and wont let me connect again as it says, 'The settings saved on this computer for the network do not match the requirements of the network'...Why...
That message means that your wireless security key has been changed to a different password. All you need to do is go to Network and Sharing Center > Manage Wireless Network, then delete all the listed wireless profiles there. Now click on Add > Add a Network that is in range of the computer > Choose your network and connect. Make sure to type in a correct network key. That should do it.
Apr 18, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Trouble getting my router to go to wireless
A few things to look at:
1) On the front of the router, is the wireless LED lit up?
2) If it is not then it is either disabled or dead. Connect the router to your pc by cable and in a browser window enter 192.168.1.1.
3) At the login screen enter admin for the user and password for the password.
4) Once you are logged in, use the wizard to setup your wireless connection.
Good luck and thanks for using FixYa
Mar 26, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Cannot connect to router wirelessly.
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
May 09, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
My network wireless adapter keeps dropping off
I would check with HP and see if they have a Vista driver for the wireless card. It sames to be the driver is in consistant.
Jan 03, 2008 | Computers & Internet
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
Oct 20, 2007 | Computers & Internet
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
4,223 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
