Question about Refrigerators
WE keep getting an ER message and the frige stops working. At first we unplugged it and it reset, but this time that is not working. When it is working there is a really loud humming noise, no problems with the freezer. Help
  • crystine63 Sep 13, 2008
    The error message is FF, I have been told by LG it is a freezer fan issue. Model is LRBC22544ST
  • 76 Answers
Hey, plz provide me with a make and model num for youre fridge,aswell the ER code and or message it gives you.
Thank you.
Wouter.
Posted on Sep 13, 2008
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
I keep getting the E2 message. "reload paper
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Nov 30, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
Jul 06, 2009 | Refrigerators
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
