Question about Broderbund Print Shop Pro Publisher 11
Cannot determine configuration this is the error message when I try to run the program
2 Suggested Answers
SOURCE:
  • 240 Answers
SOURCE: Broderbund program CLICKART 950,000
Some programs do not install the full contents of the disk. Was there an option for full installation or part installation? Try running the program with the disc in your pc-the the art gallery clips may well be on the cd and not copied onto your pc even though the software program is.
Posted on Jun 11, 2009
How to get rid of error messages on gateway laptop Model # NE56R43u to boot up laptop.
click the start tab and in the run or search box at the bottom type in this exactly msconfig then hit enter. a window will open for system configuration. click the startup tab and then uncheck items until you find the one causing the error message, for my computer it was caused by the antivirus trying to check the internet befor the wirless had started. finding the right program or could be several programs should stop your problem
Sep 23, 2014 | Computers & Internet
Every time I start my computer windows installer tries to run a scan program. How do I stop this? I tried to X out of the program and it just keeps trying to re install ,with error messages.
Type this on RUN command at the strt menu
msconfig
after that go to Startup tab then uncheck the program that automatically start when you boot your computer, or scan your computer with an updated anti-virus so that you can determined if your computer is infected with virus
Sep 24, 2010 | Computers & Internet
I downloaded this software yesterday but it didn't run on my PC. when i installed, this message appeared on the screen & stop the process of installation. " Error 1904. Module...
Well I would remove all software to that hardware being the TV card. Reboot the pc see if the error regenerates. If not then I would reload the newest version off the manufactures site. As well I would go into the msconfig and tell it not to run on bootup.
Aug 13, 2010 | Computers & Internet
I always get 2 error messages when I open my MS Word program: 1. Please wait while Windows configures Norton Antivirus 2005. The other one is: 2. Norton Antivirus 2005 does not support the Repair feature,...
Try uninstall norton antivirus and load avira antivirus, run word program and check whether an error will come out. If no error, your antivirus might be corrupted and somehow affects your application. If error still occurs after replacing norton, uninstall office program and reinstall again.
Jul 16, 2010 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Where do find 'Browser configuration'. I am getting Error 413 message ''Entity too large'' on a website and some adice to clear it was to go into 'browseconfig' and check frst two boxes. Need to find...
Error Message: "413 – Request Entity Too Large"
Translation: The Web server has determined that the data being sent by the browser is simply too large (that is, too many bytes). This occurs when file size limits are exceeded. For example, when uploading a very large file (using a technique such as HTTP PUT), a 413 error may be returned when the Web server sees that the file size is too large.
Solution: This error is typically due to configuration or programming errors on the Web server end. It may be possible to shrink the request entity (such as uploading a smaller file). Otherwise, the Web server will need to be reconfigured to accommodate the larger entity. You should inform Webmasters of the offending sites about the trouble.
If you are using a proxy you may have to configure it to allow large packet transfers.
Jun 02, 2010 | Computers & Internet
Well went through all that didn't really find
Hi
I suppose your pc doesn't qualify the minimum system configuration required to run that software application.
G'Day
Dec 17, 2009 | Computers & Internet
Jun 10, 2009 | Broderbund ClickArt Professional...
Bsod when i tried to install win2k
Error Message: PAGE_FAULT_IN_NONPAGED_AREA
Explanation:
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Nov 20, 2007 | Microsoft Windows 2000 for PC
Hanging
could be a virus/spyware/malware, also empty you temp and history files, then restart ur pc.
Nov 12, 2007 | Intel REALTEK nc-r150201 Network Adapter
Broderbund Print Shop Pro Publisher 11 Logo
387 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
