If it is push pull, on the house side pull back the gas pipe ring about 1/4 inch insert gas hose and release ring. If it is threaded, turn gas hose, bbq side, ring counter clock wise and it will attach.
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking. The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak. To fix requires either plastic welding, or replacement of the solenoid block plastic body. To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Unfortunately, you may have to put your grilling on hold, for a bit. The drip pan is considered a body part and is not stocked by any of the independent grill parts stores. They only stock the internal workings of the grill, from burners to valves, to cooking grates, ignitors, etc.
Currently, Fiesta's website is down for construction. But, when comes back up, you can probably order the drip pan online, rather than get a free one, due to the safety recall.
I have 3 BRAND NEW packages of the drip trays! By the time they arrived, the grill had died and I gave up on getting help! If you contact me through Facebook, maybe we can come up with a way to get them to you if you still need them...
The oil pan was broken. They are made out of aluminum or cast iron. but i think it's hard aluminum. You are going to have it replace it. Don't drive the car without oil.Anyone can do it . Lift the car and secure it so it won't fall. Then remove that plastic thing you mentioned and remove the bolts around the pan . It has several . Be sure to buy a pan and gasket along with the pan.And replace.
