Question about HP Computers & Internet
I cannot fold greeting cards without getting a margin that is too big on the left side of inside page. This makes it impossible to fold the card and retain alignment.
Discovered that the settings for my new printer were set for LEGAL instead of A4.
Thanks for your interest.
I have noted your e-mail address in case I need assistance in future.
Cheers.
Posted on Sep 12, 2008
Printmaster half-fold printing on epson printer
Before printing you need to select the size and orientation and it's a good idea to look at the preview before printing. That saves a lot of paper.
Nov 19, 2017 | Epson Office Equipment & Supplies
I am rying to make a birthday card but the verse and picture are not the same way up
If you are using a preloaded or downloaded template for the card, check the amounts of folds the card will print out with.  For example, at the bottom of the screen, you may see pages 1 thru 4, so this means you will have 4 folds when the page prints.
Each page represents what will be printed on each folded section, so you will be able to edit each area to suit your needs.
Here is a great little tutorial on eHow for you: http://www.ehow.com/how_2058679_use-microsoft-publisher-greeting-card.html
Jun 19, 2011 | Microsoft Publisher for PC
When making a greeting card, I can only work with the front of the card. I want to write a personal note on the inside. How do I get to the inside. When I click on "View Project" I can see the whole...
Put the front message in just the way you want it. Then print. Flip the paper over and print your inside message. Then when you fold it, it will be inside :)
Jun 13, 2010 | Broderbund PrintMaster Platinum 16
I need to print some cards with my printer, is it possible to reduct margin to zero? I have created the document without margins, but the printer cuts part of te documents... thank you for your help!
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Mar 19, 2010 | Canon PIXMA MP210 InkJet Printer
Inside of greeting card.
Yes and no. Unless you have a printer that prints on two sides you will have to "trick" it and use the template for both. Make a front and a back. You will have to print one one side then inset it to print on the other side. Since all printers feed difrently you will have to play with this on scrap first before using your good card stock. For example I made invitations to a wedding. The couple wanted a pcture on the fornt. On my template I had to rotate the picture upside down so when it was folded in half the picture wa right side up. It also had a raised rose on the invitations so I had to adjust the image so it would print in the empty are on the front. I then had to do the inside text and makes sure the paper was inserted correctly as not to print upside down. You can do it but it is tricky, that is why I recommend some scrap paper first. Good Luck.
Apr 09, 2009 | Broderbund Print Shop Mac 2.0 for Mac
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
I have Printmaster 10 and 17. On 10, I can print to the edges of the labels and others things, on 17 I can't. I know that I reconfigured 10 to do this, but it was years ago and I can't remember the step...
Custom Paper Wizard PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard. Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
  1. In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
  2. In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
  3. If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
  4. Click Next.
  5. In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
    NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
  6. Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
  7. Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
    NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
  8. The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
  9. Click OK.
  10. To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
NOTE: If the paper stock that is added does not display in the list, click or go to Custom Paper Stock Does Not Display (Technical Note ID: 43399) for additional information.
Using the Custom Paper Wizard Tutorial
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
  1. Launch PrintMaster® 17.
  2. Click Help on the menu bar and select Help Center.
  3. Click the View or Print Tutorial icon (light bulb).
  4. Under Choose a Category, click Program Tutorials.
  5. Under Choose a Topic, click Using the Custom Paper Wizard
Oct 13, 2008 | Computers & Internet
I am making some birth annocument cards overall card sixe 17.7cm x 11.4. when folded will be8.8am x 11.4. Ihave insters to use inside with birth info these are 16.6x10.9. I have tried to set up document...
I am Satya.
Hope this will solve the problem.
1.From the File menu in MSWord document click on Page setup.
2.In the page setup window click on Margins tab.
3.In the Orientation applet of Margins Page select Landscape.
4.Next click on Paper tab.
5.From the Paper size drop down list in Paper page select Letter.
6.Finally click on OK button at the bottom of the Page setup window.
7.Now type in the poem on the left hand side and the birth news on the right hand side by indenting them using the Tab key from your keyboard.
Hope this helps.
Thank you.
Aug 14, 2008 | Computers & Internet
INSIDE MESSAGE ON GREETING CARD
Your card will fold to make an inside and outside once folded, but is seen in a page layout app differently.
Take a sheet of paper and fold it in half to represent the card you will be making.
Now open it up and lay it down on a table, with the inside of the card face down.
The outside back of the card should now be on your left, and the front of the card is on the right. Use a pencil or pen to mark it as such, if you need to.
Now when you do your card layout, the cover art and text should be on the right side of the page you create in the application.
If you flip the card over, so that the inside is now facing you, you are looking at the inside of the card.
Usually, the text and signature areas would be on the right side of this page, as well.
Now, use that same guidance when you work on 'page 2' of your document. Add the text to the right side of your page, so it will be on the right inside panel after you print and fold the card.
The final step is to print it out so that the inside and outside are in the correct orientation to each other.
Be sure to feed the paper such that the top of the card is facing the same side of the paper tray when you prnt both sides. (I sometimes make a light mark in pencil which can be erasd, to be sure it goes in the right direction, since this step is easily messed up.)
Good luck.
DigiChick
Jun 09, 2008 | Cosmi Print Perfect Platinum
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
