Question about Miele Washing Machines
I have a miele w2888wps washing machine and the wire with the spring attached has come off therubber door seal. I would like to see a diagram that shows where / how it fits back on
  • 1,462 Answers
I think you maen the outer door clamp - the one that holds seal to cabinet
it just tucks into a groove in the seal with the spring at the bottom
Posted on Sep 11, 2008
How to replace door seal miele novotonic 502
Hi Adrian,
Open machine door then turn power off. Remove 3 bolts on front of machine. Remove the soap draw and remove the 2 (or 3) screws.Separate the front of the door seal from the metal front of the machine and fold the door seal in towards the drum. Front of whole machine will now hinge open (there is a spring catch at the bottom where the pump filter is - so dont be scared to use a little force). Use a screwdriver to loosen and remove the metal wire clamp that sits around the door seal. Once off, door seal can be removed from the outer drum. Replace with new door in reverse order. Note that putting on the new door seal to the outer drum is a bit of an art and may take you a few attempts (so be patient but persistant), as you must make sure it is seated in position correctly. Good luck.
Aug 19, 2015 | Miele Washing Machines
DIY Tension Spring Spreader..... for working on front load washing machines. ...
To work on a front load washer, door seal or lock, one needs to remove the wire/spring clamp from the rubber door seal. It can be removed easily but reinstalling it can be a nightmare, it requires the spring to be extended while slipping the wire around and into a slot.
They sell a tension spring tool for about $45.00 CAN, I made one for about $20.00 and it can still be used as wood clamp in the shop. See attached photo.
I bought a Dewalt 6 inch Trigger Clamp, took out the pin and reversed the trigger, it now becomes a spreader.
Cut the sharp ends off of 2 - 2 inch nails and file a small groove at the ends, they become the spreader posts.
To attach the posts, drill 3 or 4 small holes thru the plastic clamps, then use some wire to fix the posts securely, you may also us some tape to hold the post when there is no tension on the posts.
As you squeeze the trigger it expands the spring, the wire/spring clamp was reinstalled within 30 seconds without damaging the rubber seal.
Now that the washer is repaired I will put the clamp to work in my shop.
on Apr 28, 2017 | Washing Machines
Miele w4840 door rubber seal relacement
i just replaced rubber gasket on miele w4840 it took lots of patience! there is a retaining wire on spring on front part this is easily removed. next there is a light and water line about 11 o'clock take this apart and unhook water line in order to remove these from gasket. next there is a locking wire on right side at 9 o'clock. i was able to get a flat head screwdriver and loosen the screw you can open about 1 -1.5 inch at this point the rubber seal can be removed. you have to carefully (painstakingly) put the new seal on. make sure everything is lined up right before replacing the wires took me about an hour as the gasket is difficult to put on back part on drum
Apr 16, 2012 | Miele W4840 Front Load Washer
How do I open my Miele W504 and change the motor brushes
Hi Kieron
Open door then turn off power. Undo 3 bolts around door seal. Remove soap draw. Undo the screws. Peel off door seal at front of machine and fold in towards drum. Metal spring catch located at bottom behind pump filter door. Now open up front of machine (its hinged on the right). Good luck
Feb 19, 2012 | Miele Novotronic Premier 500 Front Load...
The door gasket is twisted, how do I fix it?
There is a metal retainer with a spring on the outside of the door around the seal remove that and re-form the seal around to door panel and secure with retaining spring. If this doesn't help you will have to replace the seal.
Feb 12, 2012 | Miele Touchtronic W3033 Front Load Washer
How to remove front panel on miele w524 washing machine to replaer elementce heat
very simple ,first thing first always unplug washing machine from main socket, remove top cover reomove soap drawvremove three screw from inside soap draw, remove kick pannel at bottom to reveal drain pump ,remove door seal held by spring ,remove two scrw where door strikre goes in ,then you should beable to lift of whole front which will reval heating element
Oct 18, 2011 | Miele Novotronic Premier 500 Front Load...
The top of the rubber door seal has come away from the wire that holds it in how can I put it back
first remove the wire retainer (usually has a spring attached) then fold the rubber lip of the door seal back over the metal lip on the front of the machine when correclly positioned refit the retainer by starting at the recess where the spring sits and stetching it all around the seal making sure that it is sat in the groove where it fits, it is fairly easy to replacestarting from the spring and following around clockwise making sure that it is seated right as you reach the other end of the spring the spring will stretch allowing you to finish tucking the wire in and the spring should then tuck in to the recessed part of the seal
Jul 19, 2008 | Bosch Washing Machines
Miele WS5426 Heater Element Replacement
On the WS 5426 the elements are mounted at the bottom of the drum of the accessed by opening the front of the machine.
Removal of the elements will involve destroying the rubber seal and can be done by cutting two vertical slots with a sharp knife in the seal and then pulling hard on the seal with a pair of pliers. It is not necessary to remove the spring clamps or drip shield but it will aid access to the seal.
Mar 11, 2008 | Miele Washing Machines
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Door Seal on Miele W865
no he is right, there are 3 bolts around the seal, remove/unscrew them, pull front cover and the door will swing open.
loosen the wired coupling around the seal that holds in place and pull seal off.
Now u are ready to put your new seal back on. These is the hardest part.
good luck
Oct 22, 2007 | Miele W865 Front Load Washer
Washing Machines Logo
127 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
